Rear Kitchen
Janner
Rear Kitchen
Post by Janner » Thu Dec 28, 2017 3:34 pm
Right. So we’ve finally decided on a rear kitchen. Main question is can you use it with the tailgate shut? Or is it a case of having to keep it open for gas reasons?
It’s probably a stupid question but I can’t find answer anywhere :s
Katka
Re: Rear Kitchen
Post by Katka » Thu Dec 28, 2017 7:10 pm
We've a rear kitchen and often cook with the tailgate shut and are still here. You'll probably find though that particularly at cooler times the bongo will steam up quickly so you'll want ventilation from open windows anyway.
Janner
Re: Rear Kitchen
Post by Janner » Thu Dec 28, 2017 7:45 pm
Yeah that makes sense. Thank you! I said it was a stupid question 😂
Markas
Re: Rear Kitchen
Post by Markas » Fri Dec 29, 2017 2:50 pm
I've got a rear kitchen, spent about a month in the van over the summer and haven't gassed myself yet!! As has been said the van will tend to steam up quite quickly so often open the rear O/S window for ventilation. If it's very still you can cook with the tailgate open but the flame gets blown about so a lot less efficient.
If you're still considering your options, do be aware that some hobs like this one have the knobs down side, so easier and a lot safer to use from inside or outside.
https://www.dometic.com/en-gb/uk/produc ... -l-_-20653
The only downside is that you can't then have a glass lid over the unit to give extra worktop space when it's not in use.
Mark
ade33
Re: Rear Kitchen
Post by ade33 » Thu Jan 04, 2018 4:05 pm
Same here, we have a rear kitch and, despite my paranoia about setting the headlining on fire, we have used it successfully with the tailgate closed. We usually have the side door and/or windows open and haven't suffered any major steaming up incidents either.
Markas
Re: Rear Kitchen
Post by Markas » Thu Jan 04, 2018 9:07 pm
ade33 wrote: Thu Jan 04, 2018 4:05 pm Same here, we have a rear kitch and, despite my paranoia about setting the headlining on fire, we have used it successfully with the tailgate closed. We usually have the side door and/or windows open and haven't suffered any major steaming up incidents either.
Agreed. The only problem if the tailgate's closed is that if you have fry-up in the morning the van smells like a greasy spoon caff for the rest of the day!!
Mark
Janner
Re: Rear Kitchen
Post by Janner » Wed Jan 17, 2018 8:23 pm
So I’ve finally got a kitchen sorted, how have people attached it to the Bongo? I’ve kept my split seats in, just taken off the backs so the bed isn’t compromised too much.
ade33
Re: Rear Kitchen
Post by ade33 » Wed Jan 17, 2018 8:47 pm
Ours attaches into the seat runners, in a 2001 van.
Janner
Re: Rear Kitchen
Post by Janner » Wed Jan 17, 2018 8:57 pm
I don’t have a runner in the back. I’ve got a 96 :)
Re: Rear Kitchen
Post by Bob » Wed Jan 17, 2018 9:06 pm
If you can get some long runners from a converter or breaker they should bolt straight in, you'll just need to modify the carpet. :wink:
