Scavenger fan
Bez3110
Scavenger fan
Post by Bez3110 » Mon Dec 11, 2017 10:19 am
Hi wondering if anyone has any ideas as to why my engine cooling fans come on as soon as I start the engine when it’s freezing cold but once the cars been run a while and warmed up they switch off any help would be much appreciated as it’s sod to start on a morning now .
cutlass
Re: Scavenger fan
Post by cutlass » Mon Dec 11, 2017 10:24 am
check temp sensor on block engine ( from upstairs starter motor)- when it disconnect - cool fan run all time...
Re: Scavenger fan
Post by g8dhe » Mon Dec 11, 2017 10:48 am
The Scavenger fan is the one situated directly infront of the engine pointing upwards, it pushes air thru the engine bay. It mainly comes on when static and the normal airflow has stopped hence causing the engine bay itself to heat up.
The engine cooling fans are the ones behind the radiator which draw air in to cool the radiators, they also come on when the air con is selected to ensure that the air con radiator receives sufficient cooling.
cutlass
Re: Scavenger fan
Post by cutlass » Mon Dec 11, 2017 11:33 am
I am sorry - do not understand! :roll: temp sensor of that located on metal cover- near the selector AT, but if that temp sensor dont work right - on my bongo light lamp "glow plug"
Bez3110
Re: Scavenger fan
Post by Bez3110 » Mon Dec 11, 2017 1:45 pm
Thanks for the advice will check the temp sensor when I get home the other thing I’ve noticed since the fans started coming on when cold is when I turn the engine on it clicks straight away to say say the glow plugs are warmed ready as before there was a 10 second delay while they warmed up ?
cutlass
Re: Scavenger fan
Post by cutlass » Mon Dec 11, 2017 2:16 pm
do you run self diagnostic? what lamp "glow plug" or "hold" show you?
now my bongo light lamp "glow plug" apr 10 sec...than light "off" - after I start engine...NOTE-glow plug heated to temp apr. 50C, in this case lamp "glow plug" - "off" too....if i disconnect temp sensor on block - glow plug be warm up apr 30sec, without looking temp sensor
Re: Scavenger fan
Post by Northern Bongolow » Mon Dec 11, 2017 4:11 pm
fans come on auto when the starter battery is low or duff, they stay on because the glow plugs are on and still drawing from the duff starter batt, when the glow plugs go off the starter batt recovers enough to switch off the fans.
check alternator and battery voltages. you may even have a glow plug that is shorting out or low resistance, and pulling too much amps pulling the starter batt down.
Bez3110
Re: Scavenger fan
Post by Bez3110 » Tue Dec 12, 2017 10:50 am
Was indeed the starter battery big thanks northern bongolow and everyone else for the sound advice =D>
