I have a year 2000 v6 aero city runner.
At the front end of the sills adjacent to the jacking points it looks like part of the
sill is removable for getting access to the jacking point.
I am not really sure how this is removed. I don't want to put a lot of
effort in the wrong direction and end up wrecking it.
Can any one advise please?
Rich
Bongo Aero City Runner
Eratosthenes
Re: Bongo Aero City Runner
You definitely don't jack on the cills and nothing needs removing as far as i know. Its a while since i've jacked a single front wheel so can't remember the jacking point but someone should be along to advise, or else have a search on here for advice on old posts.Eratosthenes wrote: Tue Nov 28, 2017 10:08 pm I have a year 2000 v6 aero city runner.
Rich
Edit: in fact, here you go
https://www.igmaynard.co.uk/bongo/forum ... ing+points
I actually found this using a google search!
Eratosthenes
Mike
Thanks for your reply. I looked at the link and remembered I had viewed it some time ago. The reason I asked about the skirt/sill in the vicinity of the jacking point is that it looks like it has been made with a view to gaining better access to the jacking point. (a friend of mine had his sills really crunched by a local garage and they blamed him for corroded sills!) (there is a similar fitment to the front which I think comes off for towing). I will take a couple of pictures and see if I can post them, struggled and failed last time.
Eratosthenes
These are what I was trying to describe
the sill area
https://imgur.com/0Ajexti
the front bumper area
https://imgur.com/1mOJGFl
Followed Ian's instructions this time
the sill area
This post shows the jacking points, the concave saddle on the std jack is intended to be used under suspension mountings "Do Not Use the Sills as a Jacking Point " the metal on these vehicles is not up to it and will crumple and it is not safe to use this point.
The top diagram is for trolley jack and the bottom is for std vehicle jack.
https://www.igmaynard.co.uk/bongo/forum ... 850#p56850
Take Care
Take Care
Eratosthenes
Thanks for the information - much appreciated.
Does the picture on the top left shows a central jacking location on the front subframe? They're nearly as good as the pictures in a Haynes manualteenmal wrote: Wed Nov 29, 2017 4:34 pm This post shows the jacking points, the concave saddle on the std jack is intended to be used under suspension mountings "Do Not Use the Sills as a Jacking Point " the metal on these vehicles is not up to it and will crumple and it is not safe to use this point.
Take Care
My trolley jack is only rated at 2 tons. Will I need a heavier one to safely raise the Bongo or is two tons sufficient as I can only lift one end at the time with it?
Mark
really depends,first 2 tonne i bought was a kit from screw fix
jack and 2 stands
jack only just picked up a corner but relly struggled
and stand collapsed when my son let the van down a bit quick
bought one rated at 2.5t and it would pick up back end easy
jack and 2 stands
