Manual gearbox won't get 5th gear
langtoftnick
Post by langtoftnick » Tue Nov 14, 2017 7:47 pm
Lost fifth gear. It's in the box somewhere I guess but I can't select it. Stick just drops back out into neutral. Wlt 2.5 diesel manual 5 speed (4 at the moment)
Anyone had similar? Is it possibly linkage adjustment or terminal gearbox malfunction? 1st to 4th and reverse are fine, no horrible noises, just won't go in to 5th.
Any ideas appreciated as ever.
Nick
langtoftnick
Re: Manual gearbox won't get 5th gear
Post by langtoftnick » Tue Nov 14, 2017 10:02 pm
Answering my own post!
There is a bracket attached to the gearbox underneath to which the cables from the stick attach. This is snapped at one end so doesn't provide enough leverage in the right direction for the box to get into 5th.
Spot of weld or two should sort it out with a bit of luck.
Thanks for looking.....
Post by Northern Bongolow » Wed Nov 15, 2017 4:10 am
shortest thread ever, so, - - - - - i will try to make it longer.
may be worth a lube of the cables, for the first time since it was made. :lol:
