ODB interface location
JMH234
Post by JMH234 » Sun Nov 12, 2017 9:53 pm
Hi folks
I was wondering if someone could help i am trying to locate the ODB interface socket in my 2002 Bongo and will it be a ODB 2 or older and if older can you get something to make ODB 2 compatible. I have looked in and around the drivers and passengers footwells. Thanks for any help
Re: ODB interface location
Post by g8dhe » Mon Nov 13, 2017 1:32 am
If it has an ODBII interface then its on an added bracket on the underside of the dashboard just to the left of the steering wheel.
JMH234
Post by JMH234 » Mon Nov 13, 2017 8:59 pm
The bongo is a 2012 import although manufactured in 2002 would a ODBI I not be added when the mileage conversion was done?
Post by g8dhe » Mon Nov 13, 2017 10:15 pm
The vast majority of ECU's don't support OBDII at all! It is a simple error lamp flash code, there is no conversion to OBDII available. Later versions from late 2001 or early 2002 onwards had OBDII installed if the ECU's supported it. The error codes otherwise can be decoded using this site http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm or if your a member of the club there is a Factsheet on it asw ell.
mitchelln
Post by mitchelln » Mon Nov 13, 2017 11:50 pm
If it's fitted, the socket will be under the driver side dashboard. Mine works fine with a standard reader.
Black Aero City Runner 2L petrol with full side conversion
