cabin heat
Brokenfeather
cabin heat
Post by Brokenfeather » Sat Nov 04, 2017 5:28 pm
Hi I have a 2001 2ltr petrol bongo and although the temp gauge says engine temp is good I get very little heat in the cabin and none in the back area. If I set the mode to face and legs and 32 degrees I get a warmth on fan speed 1 but any higher on the fan and the slight warmth disappears.
everything in the engine area looks ok but something must be wrong.
Any help would be great.
wonkanoby
Re: cabin heat
Post by wonkanoby » Sun Nov 05, 2017 7:26 am
start by feeling the 2 hoses run to bulkhead and the front heater
once warmed up the should both be hot,one may be a tiny bit hotter than the other
if not the your system needs a clear out as heater radiators run hot all the time
if they are both hot you need to start looking under the dash,you will see a round bit with levers coming of
this controls the flaps that stop or allow the heat from the radiator to come in,some thing might not be attatched any more
Brokenfeather
Re: cabin heat
Post by Brokenfeather » Sun Nov 05, 2017 8:28 am
Thanks One pipe is hot the other luke warm, I have also been told that the system could have air in it can it be bled or should it just clear its self and is it something I can do?
Re: cabin heat
Post by Bob » Sun Nov 05, 2017 10:16 am
The 2 ltr engine doesn't need to be bled in the same way as the diesel or V6, but I'm guessing you could bleed the heater by gently easing the top pipe off until coolant comes out.
Make certain to was away any coolant with fresh water as it isn't good for paint work. :wink:
wonkanoby
Re: cabin heat
Post by wonkanoby » Sun Nov 05, 2017 10:59 am
it might well pay to back flush the heater radiator,its amazing the crud comes out,stick a hose on the colder side
Roy748
Re: cabin heat
Post by Roy748 » Wed Nov 08, 2017 4:59 pm
Not sure if will cure your problem but I recently cleaned my interior temperature sensor as my heating would only work at either 18 or 32 degrees.. sInce cleaning the sensor it works as it should now.
Markas
Re: cabin heat
Post by Markas » Wed Nov 08, 2017 6:32 pm
Roy748 wrote: Wed Nov 08, 2017 4:59 pm Not sure if will cure your problem but I recently cleaned my interior temperature sensor as my heating would only work at either 18 or 32 degrees.. sInce cleaning the sensor it works as it should now.
Ooh, 32 degrees sounds toasty :D I guess this is only a problem if you have digital aircon, not the MX5 twiddly knob setup?
Mark
Flanners
Re: cabin heat
Post by Flanners » Fri Nov 10, 2017 8:13 pm
Can you tell me where that is located please?
Re: cabin heat
Post by g8dhe » Fri Nov 10, 2017 10:42 pm
