bongo sills
stpn6371$
bongo sills
Post by stpn6371$ » Tue Oct 31, 2017 11:04 am
Hi All
I need to replace my driver side sill but I notice that it is part of the side panel can anyone suggest how I replace this sill please also are the front wing panels bolt on, I would be grateful for any advice .
Steve
Re: bongo sills
Post by teenmal » Tue Oct 31, 2017 1:58 pm
Yes the front wings are of the bolt on type and the sills are cut and weld/bond type.
https://www.ebay.co.uk/sch/i.html?_from ... s&_sacat=0
take Care..
Flanners
Re: bongo sills
Post by Flanners » Tue Oct 31, 2017 5:17 pm
With regard to the plastic sill trim on my 2002 it has dislodged from the fittings at the rear wheel end, can anyone tell me how to fix it back on?? Looks like the female part on the plastic trim has an opening to allow this to be pushed front to rear along the length rather than just pushing against it to force it back on, any ideas?
Re: bongo sills
Post by Northern Bongolow » Wed Nov 01, 2017 3:54 am
Flanners
Re: bongo sills
Post by Flanners » Wed Nov 01, 2017 6:38 am
No it is the plastic body coloured strip between the wheels shown in bold black on your diagram.
Re: bongo sills
Post by teenmal » Wed Nov 01, 2017 12:03 pm
Sounds like your vehicle is fitted with sidesteps/ body mouldings , if you look at the diagram you will see a list of fixings/fasteners.
https://translate.google.co.uk/translat ... rev=search
Take care.
Flanners
Re: bongo sills
Post by Flanners » Wed Nov 01, 2017 11:32 pm
Thank you that helps
