				Reverse light lense
				Posted: Tue Oct 03, 2017 1:29 pm
				by stevlor
				Hi guys, reversing without paying enough attention means I've smashed the reverse lense see pic below. Ia it possible to just replace the plastic? Seen full clusters fir sale but obviously don't want to do that.
Other alternative would just be clear tape I guess?
https://drive.google.com/file/d/1zAAq1M ... p=drivesdk
				Re: Reverse light lense
				Posted: Tue Oct 03, 2017 1:40 pm
				by Bob
				What a pain, but at least you didn't whack the bumper or bodywork.
				Posted: Tue Oct 03, 2017 2:09 pm
				by Northern Bongolow
				new light im afraid. there are 2 types so take care when buying. there are yellow indicator ones and the later white top indicator ones, both will fit on your age bongo, you usually fit the same colour as the reflective cross panel that goes between across the rear door but this can also be swapped over. these are getting harder to get now so if you can find a damaged one you could try to repair if your up for it.
				Posted: Tue Oct 03, 2017 2:32 pm
				by Ian
