Reverse light lense
stevlor
Reverse light lense
Post by stevlor » Tue Oct 03, 2017 1:29 pm
Hi guys, reversing without paying enough attention means I've smashed the reverse lense see pic below. Ia it possible to just replace the plastic? Seen full clusters fir sale but obviously don't want to do that.
Other alternative would just be clear tape I guess?
https://drive.google.com/file/d/1zAAq1M ... p=drivesdk
Re: Reverse light lense
Post by Bob » Tue Oct 03, 2017 1:40 pm
What a pain, but at least you didn't whack the bumper or bodywork. [-o<
Post by Northern Bongolow » Tue Oct 03, 2017 2:09 pm
new light im afraid. there are 2 types so take care when buying. there are yellow indicator ones and the later white top indicator ones, both will fit on your age bongo, you usually fit the same colour as the reflective cross panel that goes between across the rear door but this can also be swapped over. these are getting harder to get now so if you can find a damaged one you could try to repair if your up for it.
Post by Ian » Tue Oct 03, 2017 2:32 pm
