cambelt
recovery76
cambelt
Post by recovery76 » Fri Sep 08, 2017 12:36 pm
Hi Was reading recently that cambelts should be changed every 5 years even if the mileage is not done.
Does this apply to the bongo ?
I have only done 30,000 miles since the last change just over 4 years ago.
Should I be thinking of a change?
A smile is a small curve that straightens everything out :)
Re: cambelt
Post by Bob » Fri Sep 08, 2017 12:47 pm
Yes.
It's 60,000 miles OR 5 years, whichever comes first.
This really isn't something to skimp on as the consequences of it breaking will be dire. Read £££££££ :(
It's not a massive job on the diesel, V6 is more involved, and there's a list of other bits worth doing at the same time while the front of the engine is appart.
Hope that helps. :wink:
recovery76
Re: cambelt
Post by recovery76 » Fri Sep 08, 2017 1:02 pm
Thanks bob
I will get it arranged in the not so distant future.
Out of interest what are the other bits you mention that could be done.
Mine is 2.0 ltr petrol.?
Re: cambelt
Post by Bob » Fri Sep 08, 2017 1:15 pm
On the V6 it's the tensioner/idler and water pump from memory (mine's diesel) and I'm not that familiar with the 2ltr.
Hopefully someone will have some thoughts, or if you're using a Bongo Friendly garage they will be able to advise. :wink:
Re: cambelt
Post by g8dhe » Fri Sep 08, 2017 3:44 pm
Oh comments, that's just made me think Feb 2013 @ 157,000 Kms was when ours was done, its now up to 207,380Kms and Feb 2018 is only 6 months away :-(
Re: cambelt
Post by rita » Sat Sep 09, 2017 9:30 am
recovery76 wrote:Thanks bob
The cam belt change on the 2L is much the same as the 2.5 TD,you would normally change the Belt/Tensioner and Spring,its a 20/30 minute job for a Mechanic.
Good Luck
Robbedabongo
Re: cambelt
Post by Robbedabongo » Sat Sep 09, 2017 6:42 pm
My 2.0 Ltr petrol cam belt recently broke after only 45,000 mls.Replaced belt & tensioner,as Rita says only 20-30 minute job,but will certainly replace sooner next time.
recovery76
Re: cambelt
Post by recovery76 » Wed Sep 20, 2017 4:17 pm
Had the cambelt tensioner spring idler all changed.
The first garage I went too wouldn't do it .
The second said yes and charged £124 for fitting the kit I supplied.
Took it for the MOT failed on exhaust and emissions.
They couldn't get a an exhaust.!!!
I found one on the net and they fitted it,now passed.
This was last week.Today went out and it's misfiring.
So fitted new plugs and leads check the rotor arm.
Pouring with rain been out still misfiring.
Lit the fire- got a drink- think on it till tomorrow.
Re: cambelt
Post by Bob » Wed Sep 20, 2017 6:07 pm
You'll get there. 8)
