Front fog light bulbs
llitvack
Post by llitvack » Sat Sep 02, 2017 3:08 pm
Hi folks.
One of my original Mazda Bongo fog lights has failed, and I want to change the bulb.
When I tried to remove the rear cover (held on with three star-head screws), I found that they were seized.
I have applied WD40, and will try again later; if this doesn't work, I will take off the front bumper, and work away at the screws on a workbench -- possibly with the option of cutting the heads off the screws if they're still seized.
Before all this, though, does anyone know which bulbs are required for this particular type of fitting?
Photos attached.
Cheers from Leon
Image[/img]
Re: Front fog light bulbs
Post by g8dhe » Sat Sep 02, 2017 3:29 pm
All the lamps, fuses and diagrams are here http://www.g8dhe.net/bwm
llitvack
Post by llitvack » Sat Sep 02, 2017 3:41 pm
Thanks Geoff -- much appreciated.
Now, if I can just get that rear cover off to change the bulb...
Good wishes from Leon
chipvan
Post by chipvan » Sun Sep 10, 2017 8:33 pm
Is there a way to fit brighter bulb in fog lights?
Anything else fit
