Rear heater pipe.
Paddy
Rear heater pipe.
Post by Paddy » Mon Aug 21, 2017 10:00 pm
The rear heater pipe on drivers side has corroded and is leaking, the van has a side conversion and the rear heaters are seldom used. Is it possible to do away with the rear heater pipes and reconnect the remaining pipes in a way that everything else works as normal The van is a 2.5 diesel 4wd. Thanks in advance. Paddy.
Re: Rear heater pipe.
Post by Northern Bongolow » Tue Aug 22, 2017 4:25 am
heres how to fix it properly. but it is possible but i wouldnt advise patching in a rubber pipe with jubilee clips.
http://igmaynard.co.uk/bongo/forum/view ... =3&t=58378
Merlot man
Post by Merlot man » Tue Aug 22, 2017 9:35 am
Hello paddy
I've done This very thing on my bus , blanked off the rear heater , I used a kit supplied from Ian in the bingo fury shop .
If the steel pipes are corroded though I think I would replace them , I know I did .
Remember that if you do any work on the coolant system it must be PROPERLY bled afterwards ! :shock:
See ytube for the three videos there very good
Best of luck with it and keep us informed
Brian
