engine
oldmanpete
engine
Post by oldmanpete » Wed Aug 16, 2017 5:34 pm
starting from cold engine sounds cluncky. can hear a sucking sound. after short time warmed up all ok?
Re: engine
Post by g8dhe » Wed Aug 16, 2017 6:37 pm
and the engine type is .....
oldmanpete
Re: engine
Post by oldmanpete » Thu Aug 17, 2017 7:38 am
23/03/2000 auto free top , diesel , 2500, AT, side L S differential , 4WD, with hyper sea. From VIN plate thanks to you! PS what is hyper seat?
Lifted left seat looked in (first time) found rubber pipe blanked off (turned thro 180 black plastis clip) think I know what that is!
Pete not new to Bongos just this one.
BataanPete
Re: engine
Post by BataanPete » Thu Aug 17, 2017 10:08 am
oldmanpete wrote:23/03/2000 auto free top , diesel , 2500, AT, side L S differential , 4WD, with hyper sea. From VIN plate thanks to you! PS what is hyper seat?
Hyper seat - could be something along these lines?
< https://www.rhdjapan.com/odula-hyper-lo ... -fd3s.html >
Although why anyone would want racing seats in a Bongo is beyond me. Unless you're a 6' 10" basketball player, then it makes sense. ](*,)
Regards,
Peter
Re: engine
Post by g8dhe » Thu Aug 17, 2017 12:18 pm
I've always assumed its the flip seat/footrest behind the front seats ?
BataanPete
Re: engine
Post by BataanPete » Fri Aug 18, 2017 9:25 am
g8dhe wrote:I've always assumed its the flip seat/footrest behind the front seats ?
Lush Projects calls that flip/footrest (part no. 57-11X) a < µ?AIY > Whatever that is in English. LOL!
See the diagram at < http://lushprojects.com/bongopartsmk2/c ... f02.html#3>
Regards,
Peter
Re: engine
Post by g8dhe » Fri Aug 18, 2017 9:40 am
No its called failed translation :-) The characters are a partial transliteration of the codes used in the original text!
When Lush Projects grabbed the original site (from Mazda parts mtce. manual) it was partially translated using the translation engines of the time which weren't that effective!
BataanPete
Re: engine
Post by BataanPete » Fri Aug 18, 2017 9:46 am
g8dhe wrote:No its called failed translation :-) The characters are a partial transliteration of the codes used in the original text!
Have to put my fishing rod away for today! My brain hurts Sarge! =D> =D> =D>
Rgards,
Peter
Re: engine
Post by Northern Bongolow » Fri Aug 18, 2017 1:42 pm
oldmanpete
Re: engine
Post by oldmanpete » Fri Aug 18, 2017 2:04 pm
ah.... a post about my original question thanks. the auto pre-heat has been disconected, has manual button to press, explains sucking noise?
i am looking for garage or gadget to do engine diagnostic its a year 2000 any advice?
mitchelln
Re: engine
Post by mitchelln » Fri Aug 18, 2017 4:26 pm
Have you got the additional diagnostic port under the dash on the drivers side?
Not sure what year they started appearing. If you have one you're in luck - any OBD-II reader should work.
Black Aero City Runner 2L petrol with full side conversion
Re: engine
Post by g8dhe » Fri Aug 18, 2017 5:05 pm
Pretty certain it was 2004 (possibly late) and till the end of production, but this is only going from dates that have been reported, so the start point is not clear.
oldmanpete
Re: engine
Post by oldmanpete » Sat Aug 19, 2017 11:52 am
port on drivers side. is it blue plastic? have grey box on passanger side. canot post photos tells me my pix jp are too big
