Flasher Unit removal
Hi All - probably obvious to many but how do you release the flasher unit from its mounting bracket ?  I've got a problem with no feed to my rear drivers indicator and trying to trace the fault. Cheers Jim
									V6 Mushroom
						Re: Flasher Unit removal
It seems they just need to be pulled downward.  I unscrewed the bolt securing the fixing bracket in order to find out.
									V6 Mushroom
