Manual blinds slipping fix.DO NOT DELETE
wwaveydave
Post by wwaveydave » Mon Aug 14, 2017 3:39 pm
Hey guys,
Just thought I'd share this. I had an issue with the rear two manual blinds slipping. I bought a couple of small compression springs from the 'Bay:
http://www.ebay.co.uk/itm/261418688221
I bought the 19mm x 7mm ones.
Process is easy. Tilt the blind on an angle horizontally until it comes out of the frame.
One spring needed per blind, take one of the plastic ends off the rod, slide the spring on and put the end back on.
Reverse process to put the bar back into the frame.
It works a treat.
Re: Manual blinds slipping fix.DO NOT DELETE
Post by Doone » Mon Aug 14, 2017 6:03 pm
Thank you, I like a simple fix and have added it to FAQ, to help others. =D>
