Tail gate lights
mitchelln
Tail gate lights
Post by mitchelln » Mon Jul 31, 2017 12:44 pm
Hi.
One of my tailgate lights has gone (nearside "red").
I undid the two bolt heads just inside the door, but clearly there is more to it than that.
Please tell me I don't have to take off the internal panel and get covered in the gunky sealant on the weather proofing sheet again.
Is it worth putting a LED in? I think I read somewhere that LEDs upset the Waeco MS50 cruise control due to less current draw?
Black Aero City Runner 2L petrol with full side conversion
Re: Tail gate lights
Post by Bob » Mon Jul 31, 2017 1:58 pm
On my old type with the bolts out you slide the light unit horizontaly away from the vehicle, sideways, if you're with me. :wink:
mitchelln
Post by mitchelln » Mon Jul 31, 2017 2:07 pm
Unfortunately, on the new shape Bongos it looks like you have to take the door panel off to get at the bulbs in the rear door. Rather a faff!
If I'd known I would have put LEDs in when I had it all apart to fit the reversing camera. You live and learn.
Post by Bob » Mon Jul 31, 2017 2:12 pm
'Improvements'. :roll:
Are there bulbs in the other lights as well, or just the tailgate?
Only idle interest.
mitchelln
Post by mitchelln » Mon Jul 31, 2017 2:22 pm
There's bulbs everywhere! :D
The usual suite in the side clusters plus stop/side lights in the tailgate door. Also 2 blue tinged bulbs in the tailgate that I assume are reversing lights.
I also have a mysterious extra switch in the cab with a red LED in it which comes on when switched. Goodness knows what that does. I thought it might be for front or rear fogs, but nothing comes on.
Katka
Post by Katka » Mon Jul 31, 2017 5:20 pm
Do be careful if you install LED's. Test everything, even if there's no apparent connection. I found replacing the plate lights with LED caused the front fogs to cease working and LEDs in the brakes caused the ABS warning light to flash. I've reverted to filament bulbs everywhere except reversing lights.
mitchelln
Post by mitchelln » Mon Jul 31, 2017 8:40 pm
Yes, I'd heard stories of strange effects after fitting LEDs. Thanks for confirming. I think I'll steer clear as well then.
Rather daft of Mazda making the rear door lights such a mission on the later models.
the1andonly
Post by the1andonly » Mon Jul 31, 2017 10:48 pm
mitchelln wrote:There's bulbs everywhere! :D
this could be a variation on the Klingon cloaking device fitted to all models with silent silver or Indigo paint,
mitchelln
Post by mitchelln » Tue Aug 01, 2017 8:16 am
Funny you should say that - there was a weird shimmer when I clicked the switch ;)
Bongolia
Post by Bongolia » Tue Aug 01, 2017 5:03 pm
I have one on my 2.0L.
It is actually a shape shifter switch.
I turned mine on and like you thought nothing happened.
You can imagine my shock when I checked the rear view mirror and there was a Bald Eagle starring back at me.
Scratch
Post by Scratch » Tue Aug 01, 2017 5:22 pm
When the rear light bulb went on my 2002 bongo I got it changed at a local garage. The poor mechanic had quite a job and cut a finger in the process. £10 well spent.
