half shaft
				davepickering
 - Bongonaut
half shaft
hi dose anyone have ideas why my rear half shaft is moving out of the axle and making the disc rub on the caliper ?
						Re: half shaft
do you mean, the brake disk is rubbing on the brake pad?
Good Luck.
						Good Luck.
				davepickering
 - Bongonaut
Re: half shaft
half shaft is moving in and out of axle and pushing the brake disc against the outer arm of the calliper .
just taken the wheel and Caliper and disc off, and I can move the half shaft in and out the axle about a good 1/2"
Re: half shaft
Sounds like a bearing and or back plate problem , you need to investigate a wee bit further, its not advisable to drive the vehicle in this condition.
Good Luck.
						Good Luck.
				davepickering
 - Bongonaut
Re: half shaft
Thanks Ritarita wrote:Sounds like a bearing and or back plate problem , you need to investigate a wee bit further, its not advisable to drive the vehicle in this condition.
Good Luck.
off road at the moment when its not raining will draw out half shaft and have a good look see if it needs replacing
Re: half shaft
Has it stopped raining.
				davepickering
 - Bongonaut
Re: half shaft
sorry been sorting out for mot (passed no advisory's) new bearing had fallen apart so got halfshaft with bearing on replaced unit all good now just waiting for painting now had new arches fitted, sills and inner sills welded
						Re: half shaft
Well done.
				davepickering
 - Bongonaut
Re: half shaft
all the paint work done now just got to sort heater matrix
