mitchelln
Post
by mitchelln » Tue Jul 18, 2017 1:28 pm
Hi.
I'm fitting a Waeco MS50 cruise control unit to my tin top. I have worked out how to attach the throttle cable and I'm fairly comfortable with the wiring. However, not so sure on the vacuum pick up.
Does anyone with a 2L petrol know of a convenient tap point preferably near the the throttle cable assembly? I've studied the excellent Lushprojects diagrams, but the vacuum plumbing jumps all over the place across many pages.
Any instructions on the method of stalk mounting the control also gratefully received
Thanks!
Black Aero City Runner 2L petrol with full side conversion
Post
by Bob » Wed Jul 19, 2017 3:37 pm
Not familiar with the 2 ltr, but someone may well know.
mitchelln
Post
by mitchelln » Wed Jul 19, 2017 3:51 pm
I spent an evening studying the diagrams on lushprojects.com
I think the take off should be from 4340/43-836 on the front of the inlet manifold.
http://lushprojects.com/bongopartsmk2/c ... 1of02.html
This feeds the brake assist, so I assume constant vacuum is available at that point.
Rather nervous as I'll have to cut the pipe and use a T-piece. So if I get it wrong it'll be a right pain to sort.
Post
by Bob » Wed Jul 19, 2017 4:20 pm
Understand your caution.
On the diesel there's no need to cut, there's a take off in front of the engine.
mitchelln
Post
by mitchelln » Wed Jul 19, 2017 4:26 pm
Yes, unfortunately the petrols do not have this.
Would have made life much easier!
Post
by rita » Wed Jul 19, 2017 6:09 pm
mitchelln wrote:I spent an evening studying the diagrams on lushprojects.com
The safest way to do it is, remove existing pipe from where you intend to take the vac, use a small piece of pipe fit T piece then fit original uncut pipe to T piece. If there is a problem simply remove the adapters and fit original uncut pipe .
Good Luck.
mitchelln
Post
by mitchelln » Wed Jul 19, 2017 6:28 pm
Good idea, tricky bit is going to be finding a small piece of pipe of the same size
Mind you, if I can get the pipe off, I should be able to check a vacuum is present
It's in a rather awkward spot though. Wish me luck!
Post
by rita » Thu Jul 20, 2017 8:10 am
mitchelln wrote:Good idea, tricky bit is going to be finding a small piece of pipe of the same size
I am not sure but does the kit not come with the correct pipe/hose.
As a matter of interest did you contact your Insurance Company regarding the DIY fitting of Cruise Control to your vehicle as this can be seen as a Heavy Modification. If so did they stipulate any conditions.
Good Luck.
mitchelln
Post
by mitchelln » Thu Jul 20, 2017 8:16 am
Yes, I contacted the insurance firm. No increase in cost, but hit with the usual £25 "admin fee".
I waited until the Toad AI606 and GPS tracker were fitted to stack up the changes
Bongolia
Post
by Bongolia » Thu Jul 20, 2017 8:29 am
Post
by Bob » Thu Jul 20, 2017 8:53 am
Fitted mine, along with air spring assisters and a couple of other minor things just before renewal.
Informed insurers of mods and asked if they wanted to continue with cover at the same price or should I shop around (which I always do anyway).
Post
by rita » Thu Jul 20, 2017 10:07 am
Bob wrote:Fitted mine, along with air spring assisters and a couple of other minor things just before renewal.
Ok, what was the outcome.?
mitchelln
Post
by mitchelln » Thu Jul 20, 2017 11:04 am
Oooh. Handy site that. Thanks!
Post
by Bob » Thu Jul 20, 2017 12:42 pm
rita wrote:Bob wrote:Fitted mine, along with air spring assisters and a couple of other minor things just before renewal.
Same price as previous year.
