AFT Roof sticking
Zimbo66
AFT Roof sticking
Post by Zimbo66 » Mon Jul 17, 2017 11:06 pm
Hi everyone
Newbie here. Just bought my self a Bongo had it for two days now just came across a wee problem my AFT sometimes sticks and won't go up until I give it a push any ideas how to sort this it would be appreciated I don't know if you can adjust anything to get it to work properly
Regards John
Re: AFT Roof sticking
Post by Ian » Tue Jul 18, 2017 7:38 am
It's probably a problem with the struts. In the short term try lubricating them with bicycle chain oil (not WD40 which attached grit). In the long term you might have to send them away to get sorted.
Post by mikeonb4c » Tue Jul 18, 2017 8:07 am
Welcome. Lots of discussion in the past on this so have a search. If all electrics/switches/motors ok then people often accept having to give a slight push from inside to get the roof to do that last bit so the beeper stops. But slightly tired gas struts and/or motors combined (esp in cold weather) with stiffness of tent material are probably underlying causes. How old is yours out of interest?
Post by g8dhe » Tue Jul 18, 2017 9:36 am
Post by teenmal » Tue Jul 18, 2017 10:43 am
It is not advisable to oil or grease the struts , If you use printer paper or similar and polish the struts (chrome) until the paper shows no black marks you are good to go.
cmm303
Post by cmm303 » Tue Jul 18, 2017 10:54 am
Does the roof need the nudge to start it lifting up, or won't it stop beeping at the top without a bit of help? :?
The struts help very little at the bottom of the travel but make a big difference above half way. It's the angles 8)
Chris with BertieB
Zimbo66
Post by Zimbo66 » Tue Jul 18, 2017 11:36 pm
Thanks for replying
The van is 1996 the roof starts to work then it sticks until I give it a push it then goes up all the way and the beeper stops
Post by rita » Wed Jul 19, 2017 10:20 am
Have a wee look at the roof hinges and make sure they are free and true.
Good Luck.
