Air Lift Installation
Alan2016
Post by Alan2016 » Fri Jul 14, 2017 6:33 pm
Just bought a set of these http://air-lift.co.uk/air-helper-spring ... 0-kit.html to help with a bit of bottoming out over bumps when fully loaded. Unfortunately they came without instructions. Looks reasonable straight forward, with a bladder for each side and a thick and thin plastic plate presumably to go either end (with the thicker one to protect the valve). Does anyone know what the recommended way to install these in a Bongo is i.e. with the valve on the bladder pointing up or down?
Alan
Re: Air Lift Installation
Post by g8dhe » Fri Jul 14, 2017 7:00 pm
Post by Bob » Fri Jul 14, 2017 7:12 pm
Well found Geoff. =D>
I've an idea there's a Fact Sheet,or at least info, on here, and from memory think they need to be fitted upside down in a Bongo.
A couple of us left it to a well known Bongo garage in Plymouth, who I'll call Allan's, and very pleased with the results, too. 8)
Alan2016
Post by Alan2016 » Fri Jul 14, 2017 7:18 pm
Thanks Geoff. That shows the valve to the bottom so Bob are you saying to flip that for a Bongo and have it at the top?
Alan
Post by g8dhe » Fri Jul 14, 2017 7:21 pm
You can mount either way up as I recall, can't remember which way is preferred on a Bongo see which ever way has least flex and easiest to run from!
Alan2016
Post by Alan2016 » Fri Jul 14, 2017 7:28 pm
Thanks again Geoff.
Bob I've just had a trawl through the fact sheets and there is one called Spring Assisters which might be the one you were thinking of but the link isn't working. There is also a bit of info in previous forum posts.
Alan
Katka
Post by Katka » Fri Jul 14, 2017 7:54 pm
I installed these a couple of months ago. I have the how-to sheet but the system won't allow me to attach a pdf. Can email it to you if you PM me your email address.
It wasn't a difficult job but the pipe must be at the bottom, on my V6 it did anyway, and it was also necessary to remove the coils to pop the air-bag in. Fit the pipe before you insert the air-bag.
It took me a couple of hours each wheel.
Post by Bob » Fri Jul 14, 2017 8:30 pm
Alan2016 wrote:Thanks again Geoff.
Alan
Same problem here, I'm sure that's where I read it, but the Fact Sheet won't open. :?
pauldeb
Post by pauldeb » Wed Jul 26, 2017 7:55 am
I'm thinking of installing an Airlift suspension lift system on my Bongo also. Did you notice any change in ride quality? Also, do you guys use an on-board air control system for it?
Post by Bob » Wed Jul 26, 2017 8:53 am
Ride is much better, especially when loaded or towing, and I just have the air valve fitted externaly to adjust with a comressor or air line.
Hols pressure well.
Post by g8dhe » Wed Jul 26, 2017 9:33 am
Likewise, the air control systems are a bit overkill for a Bongo, I have mine at about 18psi and never needed to vary it to be honest, we played at the start of course but that seemed to be a good pressure.
Post by rita » Wed Jul 26, 2017 10:16 am
According to Matt Savage ...
The pipe end should go downwards and routed to your preferred valve position.
Good Luck.
pauldeb
Post by pauldeb » Wed Aug 02, 2017 7:09 am
Bob wrote:Ride is much better, especially when loaded or towing, and I just have the air valve fitted externaly to adjust with a comressor or air line.
Hols pressure well.
Thanks for the info. My plan is to install an Airlift next month.
