Steering pump fluid leak
ADAMD
Post by ADAMD » Mon Jul 10, 2017 7:54 pm
Hi All, I am leaking fluid from here.
Does anyone know what type of seal/gasket this requires?
Thanks,
Adam
Re: Steering pump fluid leak
Post by Northern Bongolow » Tue Jul 11, 2017 3:43 am
cannot see the images.
ADAMD
Post by ADAMD » Tue Jul 11, 2017 7:36 am
ADAMD
Post by ADAMD » Tue Jul 11, 2017 7:40 am
Sorry, Hope that's a bit clearer!!
wonkanoby
Post by wonkanoby » Tue Jul 11, 2017 7:50 am
ADAMD
Post by ADAMD » Tue Jul 11, 2017 9:08 am
Thanks, But looking at this, I think it is o'ring no.5 I need.
http://lushprojects.com/bongopartsmk2/1R05772.gif
ADAMD
Post by ADAMD » Tue Jul 11, 2017 7:37 pm
Anyone know the dimensions of this oring?
Many thanks, Adam
Post by g8dhe » Tue Jul 11, 2017 9:46 pm
Its not pointing at an image, its pointing to Googles servers that then redirect you to an image internally however as the URL doesn't end with an image suffix the browser doesn't know how to display it.
ADAMD
Post by ADAMD » Wed Jul 12, 2017 8:56 am
Sorry guys, not doing well with images.
here is a link
https://drive.google.com/file/d/0B5E2Pq ... UtRGM/view
Post by rita » Wed Jul 12, 2017 10:32 am
You should be able to get seals (sealing kit S10H32610A) from Mazda dealer etc.
Good Luck.
Post by Northern Bongolow » Wed Jul 12, 2017 1:26 pm
you can get a power steering additive that cleans out the pump and swells the seals, then try a gentle nip up of the bolts on the flange.
http://www.carparts4less.co.uk/cp4l/p/- ... Aq-28P8HAQ.
or this stuff.
https://www.ebay.co.uk/i/162542158141?c ... 663&crdt=0.
http://www.halfords.com/motoring/engine ... ment-325ml
Post by teenmal » Wed Jul 12, 2017 3:44 pm
ADAMD , it is not really advisable to use additives Trying to cure the leak on these particular seals, the seals need to be replaced, failure to do so can cause damage to the pump. The reservoir can fill with air and Dump the fluid.
Post by Ian » Wed Jul 12, 2017 7:17 pm
rita wrote:You should be able to get seals (sealing kit S10H32610A) from Mazda dealer etc.
We have one set in stock, see http://bongoland.co.uk/product/power-as ... ing-seals/
ADAMD
Post by ADAMD » Wed Jul 12, 2017 7:58 pm
Thanks Ian, is that the set 32-610 as shown in this picture?
Thanks,
Adam
Post by teenmal » Wed Jul 12, 2017 8:01 pm
teenmal wrote:ADAMD , it is not really advisable to use additives Trying to cure the leak on these particular seals, the seals need to be replaced, failure to do so can cause damage to the pump. The reservoir can fill with air and Dump the fluid.
You should be able to purchase the Power Steering Pump Seals for under a tenner.
