Rear wiper not working ...
bongo&4kids
Post by bongo&4kids » Tue Jun 27, 2017 12:24 am
Hi guys,
My rear wiper has stopped working today.
It happened once before randomly, and I had a look at it from outside and it started working again after gently moving it a bit. So I though it had just gotten stuck weidly that one time.
But today it has happened again, but this time it is not coming back on - no response when I activate the switch.
The rear washer IS working ok, and the front wipers are fine too. I tried some WD40 on it, but that didn't help either.
Any ideas ???
THANKS!
wonkanoby
Re: Rear wiper not working ...
Post by wonkanoby » Tue Jun 27, 2017 7:35 am
usual reason is a break in wiring loom were it goes from door into the van
bongo&4kids
Post by bongo&4kids » Tue Jun 27, 2017 3:13 pm
Thanks, i'll try to take a look at that.
pauldeb
Post by pauldeb » Fri Jul 14, 2017 8:07 am
Try to check the fuse as well.
Post by Northern Bongolow » Fri Jul 14, 2017 11:55 am
ive heard the same fuse covers the wipe and the washers, if this is so its unlikely to be the fuse, i think also that the front and rear systems are on the same fuse, so if the front one works - - - - .
bongo&4kids
Post by bongo&4kids » Sat Oct 14, 2017 11:24 pm
I got round to investigating the rear wiper issue today, and sure enough, the wires had broken in the loom where they run from the door into the van.
Repaired it and now working again.
Thanks for your help!!!
Post by Bob » Sat Oct 14, 2017 11:29 pm
Nice one, always helpful to know how a problem is fixed. =D>
