Diagnostic port
Markas
Diagnostic port
Post by Markas » Mon Jun 26, 2017 6:51 pm
Hi all,
While poking about under the dash of my new toy (2.0 tin-top, 1999), I found the diagnostic port. I presume from the shape of the casing that it's not an OBDII port.
Is it possible to get a link cable to go from the Mazda port to an OBDII port? Does it communicate with OBDII code readers?
I could then plug my code reader into it and see what's going on with engine temperatures. (That's another story on another thread :?)
Thanks in advance for any replies,
Mark
Mark
Re: Diagnostic port
Post by g8dhe » Mon Jun 26, 2017 7:52 pm
Unless your a VERY late model, it doesn't talk OBDII it flashes lights at you instead for which you need an eyeball is all!
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
the1andonly
Re: Diagnostic port
Post by the1andonly » Mon Jun 26, 2017 7:54 pm
looks like geof got there first
short answer its not OBD2 obywan (obd 1)
some light reading
http://mazda626.net/topic/39240-djdevon ... -i4-or-v6/
same system as mazda 626 ford probe some vids on youtube showing how to read
MECS-II (OBD-I) Diagnostics
1993-1995 Mazda MX-6/626/Ford Probe (2.0L MTX & 2.5L ATX or MTX)
Source: http://homepage.ntlw...nt.htm#malfsrso
Source: http://www.scpoc.com...ntMod/codes.htm
mitchelln
Re: Diagnostic port
Post by mitchelln » Tue Jun 27, 2017 9:43 am
Hi.
On my 2003 2L tin top I've just bought I have the normal bongo type port on the passenger side, but I also have an obviously added port on the driver side that looks suspiciously like a standard ODB II.
Should I plug in my diagnostics reader and see what happens? ;)
Black Aero City Runner 2L petrol with full side conversion
Re: Diagnostic port
Post by g8dhe » Tue Jun 27, 2017 11:36 am
Yes, those that have the added OBDII port will work it seems with normal readers.
mitchelln
Re: Diagnostic port
Post by mitchelln » Tue Jun 27, 2017 12:07 pm
Okay, thanks for that. I'll let you know how I get on!
Markas
Re: Diagnostic port
Post by Markas » Tue Jun 27, 2017 9:05 pm
mitchelln wrote:Hi.
I'm guessing that as mine's a '99 model it won't have an OBDII port then :( If it ever stops raining here I'll have a dig around under the driver's side of the dash just in case!!
Mark
Katka
Re: Diagnostic port
Post by Katka » Wed Jun 28, 2017 2:48 pm
I throw this in just in case one of the electrical experts can see if it might apply to Bongos. It's taken from a Polish forum, that I came across when investigating ABS warning light. I used an online translator which might explain the mangled English.
I couldn't upload the pdf so attach a link to it https://yadi.sk/i/xc5iK2wE3KZwDK
mitchelln
Re: Diagnostic port
Post by mitchelln » Mon Jul 03, 2017 9:11 pm
Well, I plugged my ODB II reader into the extra port on the driver side and it worked. No errors :)
I assume it was fitted when the conversion was done.
Re: Diagnostic port
Post by g8dhe » Tue Jul 04, 2017 9:12 am
The ones I've seen pictures of appear to have been added at manufacture, but do indeed look like an add on.
mitchelln
Re: Diagnostic port
Post by mitchelln » Tue Jul 04, 2017 9:24 am
Interesting. I'll follow the wiring back and see where it goes.
Bongolia
Re: Diagnostic port
Post by Bongolia » Tue Jul 04, 2017 11:09 pm
mitchelln wrote:Well, I plugged my ODB II reader into the extra port on the driver side and it worked. No errors :)
Can you see live data like injection duration, O2 & maf volts etc?
Can you post the ECU number?
mitchelln
Re: Diagnostic port
Post by mitchelln » Thu Jul 06, 2017 3:09 pm
I'll plug in again at the weekend and see what's available.
mitchelln
Re: Diagnostic port
Post by mitchelln » Sun Jul 16, 2017 8:59 pm
Hi.
I plugged in the reader again and I do indeed get live data from lots of sensors. Not sure which menu would give me the ECU number.
The harness and bracket look pretty factory fit to me.
Sorry for the delay.
Bongolia
Re: Diagnostic port
Post by Bongolia » Thu Jul 20, 2017 2:00 am
mitchelln wrote:Hi.
It will be on the ECU itself.
I would also be interested in a pix of the Mazda diagnostic port under the glove box if that`s possible.
