Starter Battery Not Charging - Help
stevlor
Post by stevlor » Mon Jun 26, 2017 5:03 pm
Hi everyone,
Need my bongo fully functional for July and August due to work, and she's chosen the week before it all starts to have a little problem with the starter battery (I guess better now than in the middle of work!)
Bought Bongo second hand about 18months ago (N reg) and the starter battery has gone flat at least twice and needed jump starting (left my hazard lights on for a few hours, and then sat in the car with headlights on and engine off once!). Both times I was a little surprised that the battery had run flat (the lights were only left on for 30 mins I think.) but I thought - old battery what can you do. I bought a jump starter battery pack from halfords, and when I hadn't used the bongo for a week again the battery went flat, but started after I used the jump starter.
Now though something else is happening. Completely dead, so that it's not even close on first attempt, and I hadn't left it for more than a day, couldn't see anything I'd left on etc. Used jump starter and it *just* got it going. Took it for a 20-30 minute drive - parked it up. Dead again in 20 minutes (completely dead). Jump started it from my sisters car - another 20 minute drive to home. Parked it up, and tried to start it straightaway - completely dead.
So, with my limited techie knowledge, I'm thinking either a) knackered battery, b) knackered alternator or c) both.
Is there any way of knowing which option? Have I missed something else?
About 9 months ago I fitted a leisure battery with a split charge relay kit VSR in it. Could it be related to that?
I don't want to buy a new battery for it to continue happening. Is it worth taking it to a garage as I only have 3 days to get it fixed?
MalcW
Re: Starter Battery Not Charging - Help
Post by MalcW » Mon Jun 26, 2017 5:14 pm
Hi Stevlor
Mine has just done the same, and it was the battery; it just wasn't taking and holding a charge. I would have thought that if you fitted a split charge relay 9 months ago you would have had issues before now.
stevlor
Post by stevlor » Mon Jun 26, 2017 6:39 pm
Thanks MalcW,
Is there any way to check this? And where did you end up getting a new battery from?
stevlor
Post by stevlor » Mon Jun 26, 2017 7:22 pm
Post by g8dhe » Mon Jun 26, 2017 7:55 pm
If the alternator wasn't charging the battery then the Charge light would light up normally. But from the sound of it you have an old Starter battery that needs replacing, they don't last forever! Take it to a garage or Halfords and ask that they test the battery.
MalcW
Post by MalcW » Tue Jun 27, 2017 9:11 am
Hi Stevlor
I got mine online from https://www.tayna.co.uk/. Next day delivery, well packaged etc.
stevlor
Post by stevlor » Tue Jun 27, 2017 9:52 am
Thanks guys,
Would this one be ok, just a bit confused by the difference between type 335 and 249:
https://www.tayna.co.uk/S4-028-Bosch-Ca ... P9709.html
Post by g8dhe » Tue Jun 27, 2017 11:38 am
Yes that's fine, the last set of 3 numbers define specific batteries but are not a standard each one varies by manufacturer!
Post by rita » Tue Jun 27, 2017 12:08 pm
Free delivery here might help a wee bit.
http://www.justcarbatteries.co.uk/bosch ... s4028.html
stevlor
Post by stevlor » Tue Jun 27, 2017 12:27 pm
Thanks guys, I've had to order the slightly more expensive one from Tyna as they do next day delivery and justcarbatteries couldn't do it. Fingers crossed it resolves the issue - will let you know :)
