Oil cap
Cerys 458
Oil cap
Post by Cerys 458 » Sun Jun 11, 2017 2:37 pm
Just had a cracking 10 days away but now I've come to check Beryl's oil and found out she's a bit low, so found the dip stick but can't find the filler cap? Am I just being a big dipstick? Just for good measure, because of my conversion I can't put the passenger seat all the way back,
She's a 2l petrol lpg converted if that makes a difference
Gasy
Re: Oil cap
Post by Gasy » Sun Jun 11, 2017 3:22 pm
Just had a quick look on lush projects for you
On the 2ltr petrol the oil filler cap appears to be on the drivers side
If you are auto gears you could check your gearbox level while on that side ( there's no filler cal for auto box just dip stick )
Re: Oil cap
Post by Bob » Sun Jun 11, 2017 4:14 pm
I'm pretty sure the V6 is the same.
The engines were designed for cars with a normal bonnet arrangement so it wouldn't make much difference.
Cerys 458
Re: Oil cap
Post by Cerys 458 » Sun Jun 11, 2017 4:17 pm
Thanks guys,, sorted it's under the drivers seat,
Dipstick out #-o =D>
