Fuses
Posted: Mon Jun 05, 2017 11:53 am
by MalcW
Hi All
I've found that all of the fuses by the driver's door are really tight; by tight I mean I can't remove any of them using the little tweezer thingy that sits in the fuse board. Is this normal? Should I get something more substantial,pulling each one out in turn and cleaning them up? I wouldn't like to be out and about one day and need to change a fuse, only to find it isn't possible!
Cheers,
Malc
Re: Fuses
Posted: Mon Jun 05, 2017 12:45 pm
by cmm303
Assuming you are talking about the fuses inside by the drivers right knee.
They do feel a bit stiff especially if they have not budged for a while. They are only held in place by friction.
Re: Fuses
Posted: Mon Jun 05, 2017 12:50 pm
by MalcW
Hi Chris
Those are the ones, yes. On other vehicles in the past I've been able to remove fuses relatively easily, but these seem extra tight. It all started when I was looking for a suitable power supply to a low coolant alarm - which is fitted now but still not powered.
Cheers,
Malcolm
Re: Fuses
Posted: Mon Jun 05, 2017 1:22 pm
by Bob
I wonder if a quick squirt of contact cleaner would help.
Re: Fuses
Posted: Mon Jun 05, 2017 1:25 pm
by rita
Malcolm, you may need to give them a wee wiggle first (not too much).
How Old is your vehicle.
Good Luck.
Re: Fuses
Posted: Mon Jun 05, 2017 2:28 pm
by Northern Bongolow
im the same and fat little fingers dont help, i use a pair of small pointed nose pliers gently of course, mind you dont crack them.
Re: Fuses
Posted: Wed Jun 07, 2017 11:03 pm
by Jimbobvfr400
If they're that tight then they're probably also really tarnished and mucky. For the price of a few fuses I'd probably just replace them, who could be bothered to clean fuses.
