Oil Level Sensor
gilest
Oil Level Sensor
Post by gilest » Sat Jun 03, 2017 9:34 am
Can anyone help with where I ca find the wiring diagram for the Oil Level Sensor? Or where the sensor connects into the loom? I am assuming the "thing" I am referring to is an old level sensor. It is located on the side of the oil sump above the drain plug. It has two wires and a plug attached - but at the moment not plugged into anything!
I have seen mention of an oil level sensor in the forum so assume this is not an aftermarket addition.
Giles
Re: Oil Level Sensor
Post by g8dhe » Sat Jun 03, 2017 10:50 am
gilest
Post by gilest » Sat Jun 03, 2017 11:55 am
Hi g8dhe
Thanks. I have poured over the wiring diagrams but I cannot find this sensor. Are you able to point me in the right direction/page?
Giles
Post by g8dhe » Sat Jun 03, 2017 1:18 pm
? You don't say what engine you have so .......
but if you go to the Index Image
look under "O" for Oil and there listed there, then click the link and it takes you to the circuit, click the next page Imageand it shows where the connector is located.
You could also look on the Mechanical diagrams for your engine and version http://lushprojects.com/bongopartsmk2
WestyK
Post by WestyK » Sat Jun 03, 2017 6:08 pm
Hi.
I am very new to Bongos so don't know whats standard on all models as I only have experience of my 95 Diesel but would be surprised if there was a level sensor as standard. More than happy to be proved wrong as every day is a school day :D
What it could be is an aftermarket oil temperature sensor, This is a common location for oil temperature sensor as you want to know how hot the oil is entering the engine. Mostly used in Motorsport and tuned / modified engines though guess it would be useful to know with our vulnerable diesel engines too.
Post by g8dhe » Sat Jun 03, 2017 10:35 pm
The diesel has both level and pressure, but the petrol versions only have pressure.
Post by Bob » Sat Jun 03, 2017 11:13 pm
Useful snippet, thanks Geoff. 8)
WestyK
Post by WestyK » Sun Jun 04, 2017 1:05 am
Well I said I wasn't an expert and happy to be told I am wrong :oops: Sorry.
Do all Diesels have a level switch or was it just later models.
How does it indicate the low level?
Genuinely interested as I haven't noticed anything on mine and think it would be really good to know. :wink:
Post by g8dhe » Sun Jun 04, 2017 9:51 am
All three versions from 1995 to 2000 seem to have the same complement of sensors, diesels having both and petrol having only pressure. You can check easily enough by looking in the Index of the circuit diagrams under "O" for oil ;-)
Post by rita » Sun Jun 04, 2017 1:25 pm
WestyK wrote:Well I said I wasn't an expert and happy to be told I am wrong :oops: Sorry.
The latter (after 1999) may not have the Low Oil Sensor owing to the change in the engine crankcase sump arrangement.
If fitted the Low oil Level is Indicated by the Oil Warning Lamp on the dash (instrument cluster)
Good Luck
