What cable size should I use ( I have a roll of 4 amp
Electrical LED lights
Right I am at the stage where I am about to wire the interior lighting for the Wasp. I have 5 off 5 watt LED units to fit on a separate ring circuit.
) and what fuse rating would be recommended for this?
Re: Electrical LED lights
You fuse for the rating of the cable, the fuses ONLY protect the cable, not the devices on the circuit!
A 5Watt LED will draw 5/12 Amps and there are 5 of them so 2Amps.
Cheers Geoffg8dhe wrote:You fuse for the rating of the cable, the fuses ONLY protect the cable, not the devices on the circuit!
So 4 amp cable is Ok then?
And just one fuse?
Yes 4Amp is fine and 1 fuse you don't need a ring main your cable is adequate to handle the current without a ring!
The rating of the switch also needs to be adequate for the load.
Chris with BertieB
Got it, thanks.
