Gas strut spec
davidf
Gas strut spec
Post by davidf » Tue May 16, 2017 1:57 pm
Does anyone know the correct spec for the gas struts to lift the Auto FreeTop roof - ie what figure should they be pressurised to? Recently replaced mine but have been told the roof is slow to rise.
thanks
Re: Gas strut spec
Post by Bob » Tue May 16, 2017 2:29 pm
Are you running the engine as you raise the roof?
It takes a fair bit of power, and generaly isn't fast. 8)
Re: Gas strut spec
Post by g8dhe » Wed May 17, 2017 12:20 pm
Mine with new gas struts takes about 25 seconds https://youtu.be/NOdxmvxyJco
cmm303
Re: Gas strut spec
Post by cmm303 » Thu May 18, 2017 8:16 am
If you've got new gas struts (presumably matched to the original part number) and the roof is still struggling it is probably another problem. The running gear can clog and seize. The motor wiring connections can develop resistance and drop volts. The motors themselves can lose power.
Assuming you have the engine is running, I'd start with checking that the lifting mechanism is clean and runners run freely.
Chris with BertieB
davidf
Re: Gas strut spec
Post by davidf » Fri May 19, 2017 5:21 pm
Thanks everyone. I've timed the roof and it takes about 25 seconds with the engine running, so sounds as though I was worrying unnecessarily..
