Exhaust gaskets
Exhaust gaskets
Hi guys,
I've been unable to source the no1. exhaust gasket directly leading off from the turbo (KL1540305)
Does anybody know if the no2. will do the job? (WL0140305)
http://lushprojects.com/bongopartsmk2/c ... no=.html#9
Re: Exhaust gaskets
I used the same crush washers throughout my exhaust. They were thrown in by bongospares with a secondhand downpipe so no idea about part numbers.
Chris with BertieB
Re: Exhaust gaskets
Could you pop down to your local Quack Fit and ask them to match it?G-meister wrote:Hi guys,
Re: Exhaust gaskets
Thanks for the info Chris,
I would get it matched but it's still in place until the garage looks at it.
Re: Exhaust gaskets
Sorry. I thought you were doing t yourself.G-meister wrote:Thanks for the info Chris,
I would think the garage would just send it off to get it matched by their factors.
Probably the same as the Ranger I would guess.
If you could get the part number they use it could be a useful addition to the parts cross over DB on here.
Good Luck.
Re: Exhaust gaskets
Think they call it a squash ring gaskey
Every auto spates shop sells them
Halfords will do for deffo just measure diameter
And order of eblay
And order of eblay
Re: Exhaust gaskets
OK great, thanks for your help all
Re: Exhaust gaskets
Wooden ruler measurements of the washer (Not crushed) in the pic I posted earlier:
OD 68.5mm
ID 56mm
Thickness 6mm-6.5mm approx.
OD 68.5mm
ID 56mm
Chris with BertieB
Re: Exhaust gaskets
You should be able to get gaskets from your local Harrods .
http://bongoland.co.uk/product/exhaust-gasket-bolt-set/
And
http://mazdabongo.com/catalog/mazda-bon ... all-model/
Good Luck.
And
Good Luck.
