batteries
ribbleman
batteries
Post by ribbleman » Fri Apr 28, 2017 12:15 pm
Hi All, Can you isolate one of the starter batteries and just use one?
Re: batteries
Post by g8dhe » Fri Apr 28, 2017 1:12 pm
What are you trying to achieve?
but yes you can always disconnect the -ve terminal, assuming you have a dual starter battery setup.
Gasy
Re: batteries
Post by Gasy » Fri Apr 28, 2017 3:50 pm
But make sure you tape up the live cable you take off as it will be live from the other batt
Re: batteries
Post by Bob » Fri Apr 28, 2017 4:13 pm
I'd leave the positive connected for that reason. :wink:
Unless you're removing the battery, then tape up securely as suggested. 8)
