Rear wiper removal
Bez3110
Rear wiper removal
Post by Bez3110 » Sat Apr 15, 2017 5:02 pm
Rear wiper arm is getting tired so was going to paint it I've taken nut off but it's still stuck solid is there another nut behind panel I need to take off ?
Re: Rear wiper removal
Post by Northern Bongolow » Sat Apr 15, 2017 8:05 pm
nope, not anything else holding it, just needs a little puller or pulling off straight.
you can get something like this or cheaper on line.
http://www.halfords.com/workshop-tools/ ... moval-tool.
heres a drawing of the wiper mechanism.
dont wreck the arm as they are hard to get hold of and unique to the bongo. you can also wreck the gromit or even the motor behind so take care.
Bongolia
Post by Bongolia » Sat Apr 15, 2017 8:11 pm
No other nut, its just stuck on the spline. The shaft is steel and the arm is an alloy and they corrode .
A way that works for me is to lift the arm off the screen and work it in and out against the shaft pulling it up and down. After a bit of heavy handedness they usually let go, dont be tempted to rotate it though as this can damage the motor.
A bit of WD40 on the wiper shaft may help. [-o<
Bez3110
Post by Bez3110 » Mon Apr 17, 2017 8:11 pm
Thanks for the helpful advice took a bit of wrestling to get it of but got there in end
Post by Bob » Mon Apr 17, 2017 8:31 pm
Another good result. =D>
alant54
Post by alant54 » Mon Apr 17, 2017 8:47 pm
Where would bwe be without our resident experts.. :?: ..always helpful good advice on here..... =D>
Alan
Alan...still plodding on....!
