what is this?
the1andonly
what is this?
Post by the1andonly » Sat Apr 08, 2017 7:32 pm
Two pictures of my mother in laws neighbours bongo
is there a pipe missing off the bit in middle
this pipe (down by the autobox filler pipe) seems to have a nut fitted
are either of these a cause for a recent episode of smoking (white/grey)
Bongolia
Re: what is this?
Post by Bongolia » Sat Apr 08, 2017 7:37 pm
It looks like an air solenoid. Is this a 2.0 or V6?
If it is then they sometimes have an open spigot like that.
Where is it on the engine may be able to track it from the Lush Projects site.
Whats the issue with the smoke?
If it is a diesel
is this the component in this image above the inlet? If yes It does show a pipe connected.
https://goo.gl/photos/d2SMGUwuvM2cZW487
the1andonly
Re: what is this?
Post by the1andonly » Sat Apr 08, 2017 7:56 pm
Its a diesel
and above the inlet a pipe is missing in comparisson to your picky
It smokes when the throtle is blipped when cold
Bongolia
Re: what is this?
Post by Bongolia » Sat Apr 08, 2017 8:02 pm
Its part of the EGR/cold start I believe so could well be related to your issue.
I am not sure what the ferrule nut is though. If someone (NB?) doesnt come up with an answer I can check it out Monday.
Whereabouts is the ferrule nut?
Has this issue started recently or following engine work?
the1andonly
Re: what is this?
Post by the1andonly » Sat Apr 08, 2017 8:13 pm
smoking recently i think a service was done a few weeks ago
will check tommorrow
the pipe is down by the autobox filler pipe
Bongolia
Re: what is this?
Post by Bongolia » Sat Apr 08, 2017 8:30 pm
I think the ferrule nut is a separate issue as it does not appear to be on the power train, more likely related to fuel filter or the like. none the less it needs to be identified as safe to remain disconnected.
However you can see in this image that the missing pipe runs to what appears to be a non return valve ( the black barrel shaped object) this then continues to the induction pipe very near the fuel filter. It would seem likely that this has been knocked off while working in that area. It should be easy enough to track it back if you start from the induction pipe.
https://goo.gl/photos/mZxLL7KQCKoQUCgSA
the1andonly
Re: what is this?
Post by the1andonly » Sat Apr 08, 2017 8:45 pm
thanks will have a word and look tomorrow before I go back home.
need to get mine ready for Easter. not much more than fill with food clothes and fuel.
Bongolia
Re: what is this?
Post by Bongolia » Sat Apr 08, 2017 8:53 pm
Let s hope the weather stays like it has been today [-o<
the1andonly
Re: what is this?
Post by the1andonly » Sat Apr 08, 2017 9:23 pm
its been absolutely stunning on the Lincolnshire east cost
even sat on the beach at sutton on sea and chips at Salty's Mablethorpe
what a weekend
compensation for being at the mother in laws!
Re: what is this?
Post by Northern Bongolow » Sat Apr 08, 2017 11:15 pm
whats been said above is correct, the missing pipe from that stub should go to the large air inlet pipe nipple via the little one way valve, look for a hole in the inlet pipe near the rear of the head the nipple can break off. the solenoid shown is to control the on or off on the egr, theres 2, one next to it is its pair, quite often these get butchered or bypassed if the egr has been blanked off or has stuck in one position or the other.
the1andonly
Re: what is this?
Post by the1andonly » Sun Apr 09, 2017 12:22 pm
thanks for the reply
i've shown the info to andy
and sent the links to him so that he can join the forum and ask his own question here rather than pester Ian on the phone.
thanks again.
soon be time for fish and chips at the seaside then home.
Re: what is this?
Post by Ian » Mon Apr 10, 2017 1:28 pm
Northern Bongolow wrote:whats been said above is correct, the missing pipe from that stub should go to the large air inlet pipe nipple via the little one way valve, look for a hole in the inlet pipe near the rear of the head the nipple can break off. the solenoid shown is to control the on or off on the egr, theres 2, one next to it is its pair, quite often these get butchered or bypassed if the egr has been blanked off or has stuck in one position or the other.
Can anyone point me and Andy at the correct part number on Lush Projects?
Re: what is this?
Post by Northern Bongolow » Mon Apr 10, 2017 9:35 pm
93-5104 on this link ian, and the little valve to the next pipe 1312.
http://lushprojects.com/bongopartsmk2/c ... 1of02.html.
the pipe quoted should also have silver heat shielding round it to protect it from egr heat,
the link below shows the valve 13-995 on the link above
https://www.google.co.uk/search?q=mazda ... F_gEqqhQnM:
the missing pipe goes on to the little stub on 1375 on the thick black air pipe on this link.
the1andonly
Re: what is this?
Post by the1andonly » Mon Apr 10, 2017 10:14 pm
Thanks NB
Andy remembers the silver heat shroud.
With a bit of luck he'll be sorted soon.
You can be sure he'll moan about the cost
"i'm a yorkshire man thowst nose" (long O)
"where's my coat"
bullshead52
Re: what is this?
Post by bullshead52 » Sun Apr 23, 2017 12:01 pm
Help! Still having problems with blue and white smoke, it all started from before I serviced my 2.5TD. changed oil and air/fuel flitters. I have also added a new one way valve on the egr as this was missing and as advised on this forum, this made no difference. I have also blanked of the EGR no difference. Fitted new glow plugs no difference. the blue and white smoke is coming out all the time when running where it started when idling. this engine has always used a lot of water, having to always check water levels before going out anywhere. somebody said it could be head gasket which id leaking into the exhaust side, I have checked the oil and there is no sign of water in the oil, no loss of power just slight missing on start up but once its gets over a 1000 revs it clears. Well I think I have mentioned everything, anyone with any other suggestions please. look forward to reading the replies. :?
