Instrument panel removal.
MalcW
Post by MalcW » Sun Mar 12, 2017 11:52 pm
Hi all. Is removing the instrument panel as simple as just unscrewing the 4 obvious screws, or is there more to it.? I'm thinking of fitting the led for a Haydn LCA in the top hood of the removable bit. Ta.
Re: Instrument panel removal.
Post by g8dhe » Mon Mar 13, 2017 12:01 am
mikeWalsall
Post by mikeWalsall » Mon Mar 13, 2017 12:03 pm
Release the catch and drop the steering wheel onto the sat ..
Remove the four screws from the black bezel / trim ..
Remove the four screws from the white retaining clips ..
Un plug the wiring connectors (they are all different an can only plug in to the correct ones ..
You have to wiggle the clock unit a bit to get them out of dash ..
MalcW
Post by MalcW » Mon Mar 13, 2017 3:28 pm
Excellent, many thanks to you both.
