coolant alarm
bongobearett
coolant alarm
Post by bongobearett » Thu Feb 16, 2017 11:42 am
we have a coolant alarm fitted tell you of a possible over heat, well we had to get an auto electrician out to fix a problem since discovered he has cut the wire on our alarm. is this an easy fix
Re: coolant alarm
Post by mikeonb4c » Thu Feb 16, 2017 11:43 am
bongobearett wrote:we have a coolant alarm fitted tell you of a possible over heat, well we had to get an auto electrician out to fix a problem since discovered he has cut the wire on our alarm. is this an easy fix
Make him fix it?
And welcome!
Is it a Haydn Low Coolant Alarm?
Re: coolant alarm
Post by g8dhe » Thu Feb 16, 2017 11:44 am
Which wire ?
There are are normally only a couple he could damage, the +12 v power under the dash or the sensor wire going to the header tank under the bonnet ?
bongobearett
Re: coolant alarm
Post by bongobearett » Thu Feb 16, 2017 11:52 am
cheers,
bongobearett
Re: coolant alarm
Post by bongobearett » Thu Feb 16, 2017 11:53 am
not sure what alarm, currently at work i will check when i get home thanks
Re: coolant alarm
Post by Bob » Thu Feb 16, 2017 12:43 pm
Slide on a bit of heat shrink and solder the cut ends together?
