Anybody know how many core plugs there are behind the timing chest back cover on WLT 2.5 diesel?
Nothing shown in the manuals. I am loath to pull cover off if its not required.
Bongo 4wd refurb engine
Re: Bongo 4wd refurb engine
Yes it does thanks.
Question, I read that as two large plugs one behind the water pump and on behind the D/pump is 10-327 a small plug?
Seems to highlight core plugs when clicked but then only shows two?
Am I reading that right?
022110327 One front and one rear of engine, but as you probably know best to go in with Extra Ammunition.
Good Luck.
Good Luck.
Ta.
Locked and loaded.
Locked and loaded.
