So I could fit a gear box cooler ( 13 row alley cooler )
It took a while to fit the ally cooler
But I noticed I was running a couple of degrees cooler on the engine head temp alarm ( all good )
I then got round to fitting the gear box cooler in front of the water cooling rad
And left the number plate at the side ( I like the look )
And it obviously lets more air in to the rads and engine ( the number plate is blocking half the opening )
Engine temp remained 2 - 3c lower
But since then I've always had the caravan on the back for long journeys
But last weekend I went to see a mate 1 1/2 hours away and gave it a good run on A roads to Leicester (60-70mph) few small hills
The engine temp was averaging 75c ( down to 72 down some hills ) it was 14:00 and a sunny day ( no coat required )
I used to run 82-84c normal conditions ( before moving rad and fitting gear box cooler )
Last weekend was the first time it's had a good run with out the caravan on the back
And the drop in engine head temp is obvious
Definitely moving the number plate dropped it a good couple of C
And the gearbox cooler must be doing a good 3c drop
I'm now running a good 7c cooler on a average condition journey
Moving plate was a half hour job
Installing gear box alley cooler was a hour and a half ( once brackets were sourced ) and £70
Quite pleased with that me self
