Cigar lighter fuse
Bongocrewe
Cigar lighter fuse
Post by Bongocrewe » Sun Jan 29, 2017 5:23 pm
Can anyone advise please. Cigar lighter fuse blown when inflating tyre and scavaging fan warning light started flahing. I have replaced the fuse (numer 8) but cigar lighter and radio still not working and warning light still flashing. Any ideas please!
Re: Cigar lighter fuse
Post by mikeonb4c » Sun Jan 29, 2017 5:55 pm
I didn't know the scavenger fan had a warning light?
Post by Bob » Sun Jan 29, 2017 6:11 pm
Welcome aboard. :D
Can you let us know the age of your Bongo? Newer ones have fancier electrics. 8)
the1andonly
Post by the1andonly » Sun Jan 29, 2017 6:37 pm
upto 2001 sept (also after looks like) (diesel only)
fuse 8 radio cigarete sockets and mirrors
fuse 1 also radio and lots of other things including the ECU.
if fuse one is blown you will get the engine error flash
the sockets have rather weedy wiring and should Not be used for electric pump (bet youv'e guessed that all ready
Bongocrewe
Post by Bongocrewe » Sun Jan 29, 2017 6:52 pm
Hi, thanks for your replies so far. The age of the bongo is a 96 diesel. It is fuse 8 that has gone & we attempted to change it. The warning light that is flashing is the one that looks like a coil (the one you wait to go out before you start it) so it may not be the scavenger fan but it looked like that in the manual.
the1andonly
Post by the1andonly » Sun Jan 29, 2017 7:24 pm
try changing fuse 1 as well.
top left hand one,
Have you got a leisure battery and fuse 1 swapped to it possibly another fuse/ fusebox else where
top right 3 swaped over to liesure batt
piggy back fuses also shown
Bongocrewe
Post by Bongocrewe » Sun Jan 29, 2017 8:12 pm
Thanks, we'll try changing fuse 1 tomorrow and let you know how we get on!
Post by Bob » Sun Jan 29, 2017 8:36 pm
Pretty sure that light is just to show the glow plugs are warming, but we have an electrical expert.
Geoff will know. 8)
Post by g8dhe » Sun Jan 29, 2017 8:51 pm
If the glowplug light is Flashing then that means that the ECU is reporting a fault.
Check to the top left fuse, as that is the backup supply, if its not that then you need to use the factsheet in the Members area or this web site to get a read out of the error number http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
There is no reason why the air pump should have blown the top left fuse, the top right one yes also possibly the one on the back of the socket itself;
A web site with all the fuse types, locations, purposes and circuits affected along with the lamps and wiring diagrams is here http://www.g8dhe.net/bwm
Bongocrewe
Post by Bongocrewe » Tue Jan 31, 2017 1:29 am
Many thanks for replies. Unfortunately have now replaced both 1 and 8 fuses but problem still persists - no cigar lighter and no radio. Diagnostic chart looks a bit daunting! Any alternative thoughts would be appreciated.
the1andonly
Post by the1andonly » Tue Jan 31, 2017 7:11 pm
Bongocrewe
Post by Bongocrewe » Wed Feb 01, 2017 1:51 pm
Thanks again for latest assist. Yes, despite changes of fuses the coil warning light is still flashing. Presumably the fact that both cigar lighter and radio are not working rules out the possibility of the back fuse in the lighter being the problem? All was well until I tried pumping up the tyres - pump suddenly stopped working after a couple of minutes! Can't be sure that the coil had not been flashing before but I certainly hadn't noticed it. Despite useful Youtube videos still rather daunted by diagnostic codes - and at the moment do not have a LED to follow the instructions in the clip. Will keep trying!
Post by g8dhe » Wed Feb 01, 2017 3:40 pm
Any small 12 volt bulb can be used you don't have to use an LED its makes it more difficult, any dashboard style light is fine (not headlights or sidelights!)
Have you checked all your other electrical circuits ? Do they work, internal lights, dashboard back lights, indicators etc.
