Headlight ceramic connectors??
Gdlee1976
Post by Gdlee1976 » Fri Jan 27, 2017 9:10 pm
I've got a P Reg, 2.5L and I had a headlight that went dim so I replaced it only to have the other side do the same thing. Then the new bulb went dim so upon further investigation I've found that I can wiggle the dim lights connector and it fixes the issue. Now just tonight, there were no headlights at all until I wiggled the connectors. Seems that this is a known fault so my question is, which ceramic connectors do I need to fix this?? Just any 3 wire H4 ones?
Re: Headlight ceramic connectors??
Post by mikeonb4c » Fri Jan 27, 2017 9:35 pm
Gdlee1976 wrote:I've got a P Reg, 2.5L and I had a headlight that went dim so I replaced it only to have the other side do the same thing. Then the new bulb went dim so upon further investigation I've found that I can wiggle the dim lights connector and it fixes the issue. Now just tonight, there were no headlights at all until I wiggled the connectors. Seems that this is a known fault so my question is, which ceramic connectors do I need to fix this?? Just any 3 wire H4 ones?
If you enter ceramic AND connectors in the search box you should get some old threads returned, such as this one:
http://igmaynard.co.uk/bongo/forum/view ... connectors
Good luck, let us know how you get on.
Post by Bob » Fri Jan 27, 2017 10:21 pm
Yep, H4 ceramic connectors.
Cheap and readily available.
Gdlee1976
Post by Gdlee1976 » Mon Jan 30, 2017 9:53 pm
I've got ordered so should have them in hand soon. Hope that this resolves the issue!!
Post by Bob » Tue Jan 31, 2017 2:16 am
You may need to clean the connectors in the original plugs, and possibly tighten them a little (long nosed pliers, gentle squeeze) to get a good conection to the new leads.
Free and simple to do. :wink:
