radio wiring
leswats44
radio wiring
Post by leswats44 » Mon Jan 23, 2017 3:55 pm
Hi all, does anyone know the wire colours for speaker wiring I am having problems
trying to install my mates pioneer radio, the wireing has been altered and I can't
seem to get any responce from speakers, I tried the old battery trick (putting a
small charge across ,you normally get a buzz) but no luck. Any idea's welcome.
many thank's ( his Bongo is 1998 v6)
Les
P.s the radio work's great in my 1996 2'5 turbo diesel
plugged straight in with ISO lead
Re: radio wireing
Post by g8dhe » Mon Jan 23, 2017 4:22 pm
The wiring diagrams ? Click for the full diagrams - needs Flash;
Re: radio wireing
Post by Ian » Mon Jan 23, 2017 4:37 pm
This is an extract from the "Audio" fact sheet in the members area of the main website:
Danny from Wellhouse Leisure has provided us with the colours for the radio wiring harness:
Perm Live Blue/red
Acc Live Dark Blue
Side Lights Red/black
Earth Black/red
Front Speakers Purple Front left (white)
Blue/yellow Front left (white)
Green/red Front right (grey)
Yellow/green Front right (grey)
Rear Speakers White Rear right (purple)
Green/yellow Rear right (purple)
Orange Rear left (green)
Yellow/red Rear left (green)
leswats44
Re: radio wiring
Post by leswats44 » Wed Jan 25, 2017 6:20 pm
Hi, many thank's g8dhr & Ian,very helpful.
Les
ade33
Re: radio wiring
Post by ade33 » Mon May 14, 2018 8:35 pm
Bit of an epic thread resurrection, but thought it was worth it to say a thank you to Geoff and Ian for the useful info.
Swapped out my original, Jap-spec radio for a 'new' (eBay recycled!) double din yesterday. So nice to have a radio that actually picks something up!
Ok, I could have figured it out by myself, but with the diagram and wire colour-code listing posted here it was a breeze.
Thanks chaps.
wwaveydave
Re: radio wiring
Post by wwaveydave » Tue May 15, 2018 10:54 am
Do you guys know which of the lives goes to the ignition switch? I'd like to move that connection to go to the switch on my dash that power toggles the leisure battery connections.
Re: radio wiring
Post by g8dhe » Tue May 15, 2018 11:33 am
The A7 pin (Blue wire) is Ignition switched power,
the A4 pin (Blue/Red) is permanent back-up power.
wwaveydave
Re: radio wiring
Post by wwaveydave » Tue May 15, 2018 11:35 am
That's awesome, thank you.
TheLongRoad
Re: radio wiring
Post by TheLongRoad » Tue May 15, 2018 12:13 pm
@wwavetdave, suppose you'd need an on/off/on type switch so it draws power from either main or leisure rather than both batteries - or doesn't it matter?
2002 Friendee 2.0 ltr Petrol.
wwaveydave
Re: radio wiring
Post by wwaveydave » Tue May 15, 2018 12:30 pm
I moved the circuit to the leisure battery using a swap loom, and now the stereo is constantly on. I'd just like to put a switch in line so I can turn it off.
Re: radio wiring
Post by g8dhe » Tue May 15, 2018 12:49 pm
Common problem, often there is a software On/Off function in the menu's but not the easiest to use, my solution was buy a radio with On/Off and also a remote so could adjust and use it from the rear!
wwaveydave
Re: radio wiring
Post by wwaveydave » Tue May 15, 2018 2:24 pm
Yes, that's the way it is here. You have to run through the menus to turn it off. Not the end of the world but it's a pain if you're in a rush. I have a power switch for my Voltmeter, USB charger, Cigar charger panel on the center console powered by the leisure battery so it's no big deal to route it to there, I just need to run the appropriate cable to the switch and back out.
wwaveydave
Re: radio wiring
Post by wwaveydave » Tue Sep 26, 2023 9:58 am
Funny thing. After not getting around to getting this sorted 5 years ago, I came back to it this week. The first post I googled turned out to be my own! Long story short, somewhere in my loom the Ignition switched power and permanent back-up power have been joined and this turned out to be less easy than first anticipated. In the end I just split the Ignition Switched power from the back of the stereo loom and ran that to my leisure battery panel and it's sorted.
Re: radio wiring
Post by Bob » Tue Sep 26, 2023 8:41 pm
Well done. =D>
