FAULT CODE 12
Posted: Sun Oct 22, 2006 3:56 pm
by richieandkerry
This fault code has happened on my bongo twice spaced about a week apart. both times it has occurred it has been raining. could this have any bearing on why the hold light is flashing this fault. I've heard it's the Thottle position sensor. is it serious, is it expensive and what does it do. can anyone help :
Posted: Sun Oct 22, 2006 5:19 pm
by moonshine
Where do you get the fault codes? I occasionally get a hold light flashing and no speedo reading, which I have been told is a speed sensor fault, but I have no idea where the fault code is shown.
Switching the ignition off then re-starting usually cures it, but I'm sure one day it won't and I will have to investigate further. At the moment though, it only happens once in a blue moon, so I'll worry about it when I have to. :)
Posted: Sun Oct 22, 2006 9:17 pm
by white van man
throttle position sensor not available at the moment,being told have to buy complete pump at £1400 but working on alternatives!!!moonshine ,if your speedo is converted using a chip?bin it and fit a speedo face as this sounds like a familiar fault that i have now rectified in this way on numerous occasions
Posted: Sun Oct 22, 2006 10:03 pm
by Bonza
Had my speedo chip replaced and intermittent fault has no recurred. Dealer said its happened before with his batch of chips. Only permanent fix possibly is to ditch the chip and replace the speedo face.
Bonz
Posted: Mon Oct 23, 2006 8:21 am
by richieandkerry
I got the fault codes from the fact sheet about transmissions. How can i tell if it's been converted using a chip. Bonza who is your dealer in devon as i'm also in devon
Posted: Mon Oct 23, 2006 8:40 am
by richieandkerry
Spoke to my dealer he says the van was speed converted with a sticker. Any other suggestions as to what this problem could be. the fault is itermitant is it safe to drive
Posted: Mon Oct 23, 2006 8:41 am
by Bonza
fault code 12
Posted: Mon Oct 23, 2006 9:39 am
by antique
hi i have same problem but not intermitent try changing gear box oil and clean filter we are going to try that today, i have a second hand fuel pump and gear box coming tuesday will then swap parts over to find the fault if its not the throttle sensor will stick the gearbox in will get there in the end ?
Throttle position sensors
Posted: Mon Oct 23, 2006 1:11 pm
by richieandkerry
finally found somewhere that can get them direct from Japan. Auto link in Hants 01489 877770. reckons 4-6 weeks delivery time. price £100 inc Vat :D
fault code 12
Posted: Mon Oct 23, 2006 5:25 pm
by antique
hi have cured fault code 12 throtle sensor causing open circuit the man to talk to is simon at autotonic petersfield hampshire tel 01730893893 hope this helps ?
