Corner sensors
Dudleian
Corner sensors
Post by Dudleian » Tue Dec 06, 2016 5:12 pm
On both rear corners of my bongo there are what appear to be reversing sensors and somewhere in the van there is a beeper (one of many!) When I select reverse the beeper operates immediately and continues to beep even when therre is nowt behind me - does mean that A - the sensors are duff or B - they're not actually sensors at all......?
Why be the same as everyone else when, with a bit of effort, you can be different?
Re: Corner sensors
Post by teenmal » Tue Dec 06, 2016 6:26 pm
This feature is common to these vehicles, it lets you know that you have selected reverse gear, not reversing sensor as you know it Jim.
Dudleian
Re: Corner sensors
Post by Dudleian » Tue Dec 06, 2016 7:09 pm
That's what I thought - so what are the little doodahs that look like sensors then?
Re: Corner sensors
Post by teenmal » Tue Dec 06, 2016 7:17 pm
Dudleian wrote:That's what I thought - so what are the little doodahs that look like sensors then?
Haven't a clue they are your doodahs,it Could be reversing sensors that are not doodahing ..
Re: Corner sensors
Post by g8dhe » Tue Dec 06, 2016 8:03 pm
The original reversing sensors have one on each rear corner, two at the rear central and one nearside front. The displays are central on the dashboard are at the front centre of the vehicle and also a rear one visible in the reversing mirror. If its not that configuration then its probably a 3rd party add on.
