Bongo 1995 wiper arms?
Posted: Sun Oct 30, 2016 10:39 am
by TonyW
Hi all,
I'm trying to source some replacement front wiper arms for my 1995 Bongo ...... but can't find any anywhere?
Any suggestions??
Thanks in advance.
Tony.
Re: Bongo 1995 wiper arms?
Posted: Sun Oct 30, 2016 11:03 am
by Dr Fingers
Ditto..
surely there must be new ones from other vehicles that could fit? Someone might know.. :D
Derek
Posted: Wed Nov 02, 2016 9:03 am
by TonyW
Thanks Derek .... nothing heard/found yet. I'll post in the wanted section too.
Tony.
Posted: Wed Nov 02, 2016 9:50 am
Surely a breaker such as Bongospares would have some? I presume they're not available new?
Posted: Wed Nov 02, 2016 12:07 pm
by Ian
New wiper arms still available from Mazda for around £60 plus VAT plus delivery. Part numbers S05B67321 (offside) or S05C67321A (near side).
Posted: Wed Nov 02, 2016 9:49 pm
by the1andonly
Posted: Wed Nov 02, 2016 10:41 pm
by KMH
I have a set from my P reg, if you don't mind sanding them down and painting them. I've just moved house, so I would need to work out which box in the garage they are in before I could post them!
by Bongolia
TonyW wrote:Hi all,
Any suggestions??
Thanks in advance.
Tony.
Whats the problem with the old ones Tony?
Posted: Thu Nov 03, 2016 1:01 am
by Bongoplod
Dont know why your replacing yours,but mine were a mess of rust.
I took them off ,sanded tham down then bought a can of smooth black hammerite spray nd sprayed them.
They looked like new arms when done
Brian
Posted: Mon Nov 07, 2016 10:01 am
by TonyW
Thanks you two .... yep they're just a bit rusty and and old looking.
I've drawn a complete blank on replacements so will go with the sand sown/hammerite option.
Cheers.
Tony.
Posted: Mon Nov 07, 2016 11:04 am
TonyW wrote:Thanks you two .... yep they're just a bit rusty and and old looking.
Cheers.
Tony.
Every year or two I sand mine and smooth hammerite them (using a diy made pad of foam rubber from some stock i have and dabbing it on, to give an effect) and i do it without removing them as i understand doing that can be tricky if they've seized on and i don't see the point in stressing things unnecessarily on the old girl. Works a treat and takes minimal time.
