Bongo 1995 wiper arms?
Hi all,
I'm trying to source some replacement front wiper arms for my 1995 Bongo ...... but can't find any anywhere?
Any suggestions??
Thanks in advance.
Tony.
Any suggestions??
Thanks in advance.
Tony.
- Dr Fingers
Re: Bongo 1995 wiper arms?
Ditto..
surely there must be new ones from other vehicles that could fit? Someone might know..
Derek
Derek
Thanks Derek .... nothing heard/found yet. I'll post in the wanted section too.
Tony.
Tony.
Surely a breaker such as Bongospares would have some? I presume they're not available new?
New wiper arms still available from Mazda for around £60 plus VAT plus delivery. Part numbers S05B67321 (offside) or S05C67321A (near side).
- the1andonly
- Tribal Elder
I have a set from my P reg, if you don't mind sanding them down and painting them. I've just moved house, so I would need to work out which box in the garage they are in before I could post them!
Whats the problem with the old ones Tony?TonyW wrote:Hi all,
Any suggestions??
Thanks in advance.
Tony.
Dont know why your replacing yours,but mine were a mess of rust.
I took them off ,sanded tham down then bought a can of smooth black hammerite spray nd sprayed them.
They looked like new arms when done
Brian
Brian
Thanks you two .... yep they're just a bit rusty and and old looking.
I've drawn a complete blank on replacements so will go with the sand sown/hammerite option.
Cheers.
Tony.
Cheers.
Tony.
Every year or two I sand mine and smooth hammerite them (using a diy made pad of foam rubber from some stock i have and dabbing it on, to give an effect) and i do it without removing them as i understand doing that can be tricky if they've seized on and i don't see the point in stressing things unnecessarily on the old girl. Works a treat and takes minimal time.TonyW wrote:Thanks you two .... yep they're just a bit rusty and and old looking.
Cheers.
Tony.
