Wot dat den?
Bongolia
Wot dat den?
Post by Bongolia » Tue Oct 25, 2016 7:28 pm
https://goo.gl/photos/1XtHb3R51KDK49n17
Found this when groping about under the Bongo today.
Can anyone ID it please.
Gasy
Re: Wot dat den?
Post by Gasy » Tue Oct 25, 2016 7:59 pm
It's a left hand :shock:
I've just checked its not mine
Re: Wot dat den?
Post by Northern Bongolow » Tue Oct 25, 2016 8:19 pm
they usually are mounted via a rubber grip like thing as on motorbikes when you fit the flashers unit and similar, the mounting place isnt obvious so you will have to hunt about. in my opinion it looks like the electrical suppression unit you have inside a drill to help kill interference, but a bosch agent or lawson diesel pump specialists in edinburgh will put you straight im sure.
redrocket
Re: Wot dat den?
Post by redrocket » Wed Oct 26, 2016 8:46 am
Ive not seen one on my bongo, but have seen something similar on my motorbikes and im sure they are diodes, they only allow current to flow in one direction, im sure on my bike it was for the side stand and the clutch to ensure 1. the side stand was up and the clutch was being held in before starting the bike. I have no idea what that would be for on the bongo mind. a guess would be something possibly to do with the doors open circuit for when you hear the beep beep or for the circuit when lifting up the roof, handbrake and in park etc. or even for the alternator would be a good guess. get the wiring diagrams out and get on the hunt for the diode symbol ;)
Then again i could be completely wrong and sending you on a wild goose chase
Bongolia
Re: Wot dat den?
Post by Bongolia » Wed Oct 26, 2016 10:06 am
Thanks chaps.
I am in work today so I will investigate further.
I have popped the numbers unto the mighty Google and got some distracting results, nothing to do with motors though.
Bongolia
Re: Wot dat den?
Post by Bongolia » Wed Oct 26, 2016 10:08 am
Gasy wrote:It's a left hand :shock:
No Gasy not the hand M8 the thing........oh don`t bother
:D :D
Re: Wot dat den?
Post by Bob » Wed Oct 26, 2016 10:18 am
'Thing' is the hand.
In the Adams Family at least. :lol:
https://www.google.co.uk/search?q=thing ... 24&bih=672
Re: Wot dat den?
Post by g8dhe » Wed Oct 26, 2016 4:06 pm
Its a resistor which is related to the fuel pump;
http://lushprojects.com/bongopartsmk2/c ... no=.html#1
Re: Wot dat den?
Post by Northern Bongolow » Wed Oct 26, 2016 6:29 pm
thats the fella, good un geoff, and it shows its mounting place. =D> =D>.
any idea what it resists. :?
Bongolia
Re: Wot dat den?
Post by Bongolia » Wed Oct 26, 2016 8:21 pm
Bob wrote:'Thing' is the hand.
Yes Bob but thats a right hand! :D :D
Re: Wot dat den?
Post by Bob » Wed Oct 26, 2016 8:22 pm
Twin brother?
Bongolia
Re: Wot dat den?
Post by Bongolia » Wed Oct 26, 2016 8:23 pm
Northern Bongolow wrote:thats the fella, good un geoff, and it shows its mounting place. =D> =D>.
Second that.Or why?
Bongolia
Re: Wot dat den?
Post by Bongolia » Wed Oct 26, 2016 8:24 pm
Bob wrote:Twin brother?
Could be, I wonder if he knows what the other is doing?
:P
Bongolia
Re: Wot dat den?
Post by Bongolia » Wed Oct 26, 2016 8:37 pm
g8dhe wrote:Its a resistor which is related to the fuel pump;
I am right in thinking there are 13 variants too?
Mines No7 I think it was 1.47 ohms, seems tiny.
It did remind me of an octane plug Vauxhall used.
Re: Wot dat den?
Post by g8dhe » Wed Oct 26, 2016 9:40 pm
Nope! Its not on the electrical diagrams, only shown on the mechanicals!
The pump connections are B2-12, does anyone have the wire colours on the socket noted down or visible ?
