CUT AND SHUT
ELZE
CUT AND SHUT
Post by ELZE » Thu Oct 20, 2016 6:18 pm
I got to thinking the other day (day dreaming :roll: ) how to get more space from a Bongo then I thought about cut and shut! taking the last section of a scrapper and welding it to yours making it a stretch version :) quite a task but I have seen it done on other vehicles with pieces put in and some taken out. I think it would be cool & definitely unique. Obviously a challenge
maybe it has been tried already ??
Gasy
Re: CUT AND SHUT
Post by Gasy » Thu Oct 20, 2016 6:22 pm
Could be done I agree a long wheel base bongo
Would be a big hangover behind the rear wheels tho
Or you'd have to be sorting a longer rear prop shaft if you moved the wheels back ( big job then , brakes etc )
I used to love the shortend split screen campers ( when they chopped a few feet out the middle of the bus )
ELZE
Re: CUT AND SHUT
Post by ELZE » Thu Oct 20, 2016 6:40 pm
Well you could put a double axle in or cut out a mid section out of the donor van welding up the sliding door then slam it in between yours. Not saying it would be easy but worth a punt. trying it with two scrappers first tho'
Re: CUT AND SHUT
Post by Northern Bongolow » Thu Oct 20, 2016 8:15 pm
the roof would be long and heavy. 8)
Re: CUT AND SHUT
Post by mikeonb4c » Thu Oct 20, 2016 8:27 pm
ELZE wrote:I got to thinking the other day (day dreaming :roll: ) how to get more space from a Bongo then I thought about cut and shut! taking the last section of a scrapper and welding it to yours making it a stretch version :) quite a task but I have seen it done on other vehicles with pieces put in and some taken out. I think it would be cool & definitely unique. Obviously a challenge
I think its been done and they called it a Hiace? :lol:
Bongolia
Re: CUT AND SHUT
Post by Bongolia » Thu Oct 20, 2016 9:29 pm
I think a six wheeler would look great. Anyone a Photoshopper?
Re: CUT AND SHUT
Post by Bob » Thu Oct 20, 2016 10:30 pm
What you don't want is a No.3 axle with no drive.
It will take weight from the No.2 and you'll loose drive on all but smooth tarmac. :?
ELZE
Re: CUT AND SHUT
Post by ELZE » Fri Oct 21, 2016 10:23 am
Bob wrote:What you don't want is a No.3 axle with no drive.
So is there a front wheel drive option that could be used? then you just use two trailing axles or modify a transit one
Bongolia
Re: CUT AND SHUT
Post by Bongolia » Fri Oct 21, 2016 3:49 pm
I am wondering if you could use down-rated progressive wound springs in the third axle.
Or use 4wd Bongo with rear drive disconnected.
I did a very crude cut and paste job on an Ebay image and providing you really squint it looks very sexy.. :D
The ATF would still need some thought. #-o
ELZE
Re: CUT AND SHUT
Post by ELZE » Fri Oct 21, 2016 3:55 pm
Bongolia wrote:I am wondering if you could use down-rated progressive wound springs in the third axle.
First attempt should be with a tintop to get the basics right, then consider an elevating roof but maybe a fixed high top
Bongolia
Re: CUT AND SHUT
Post by Bongolia » Fri Oct 21, 2016 6:21 pm
Or a tin top front and an ATF rear section?
Would look like a greyhound bus stylee thing! :D :D
Bongolia
Re: CUT AND SHUT
Post by Bongolia » Fri Oct 21, 2016 6:24 pm
Bongolia
Re: CUT AND SHUT
Post by Bongolia » Fri Oct 21, 2016 6:26 pm
Well that didnt work. Try this one.
https://www.google.co.uk/imgres?imgurl= ... mrc&uact=8
Bongolia
Re: CUT AND SHUT
Post by Bongolia » Fri Oct 21, 2016 6:31 pm
Thats better. :lol:
Thinking maybe boxing in the rear arches too. What do u think? :P :P
https://www.google.co.uk/url?sa=i&rct=j ... 7395750132
ELZE
Re: CUT AND SHUT
Post by ELZE » Fri Oct 21, 2016 6:37 pm
Bongolia wrote:Thats better. :lol:
There was nothing wrong with a Dormobile :lol: :lol:
