Lone plug under near side cubby
cuchillo
Post by cuchillo » Tue Oct 11, 2016 1:46 pm
Hello,
While checking the near side, rear, cigarette lighter socket I came across this 90 degree plug:
It was all wrapped up in black tape, which I removed so that I could look at it. I did put a meter across it and its was reading 12+ volts, so permanently live. However, I did not try disconnected the batteries or pull any fuses to work out where its feed came from and what it was fused to.
Any thoughts?
(I did re-wrap it in black tape before putting it back)
TIA
Cuch
Re: Lone plug under near side cubby
Post by g8dhe » Tue Oct 11, 2016 1:53 pm
Its the plug that goes on the rear nearside socket up the back of the cubby hole. Does your rear socket work ?
cuchillo
Post by cuchillo » Tue Oct 11, 2016 2:01 pm
g8dhe wrote:Its the plug that goes on the rear nearside socket up the back of the cubby hole. Does your rear socket work ?
Ah right!
Yes the socket works.
I guess that, the original plug was removed and a new feed from the leisure battery was pulled through.
All good thanks :-)
Cuch
