Roof Vent Fan Ventilation
cuchillo
Post by cuchillo » Wed Oct 05, 2016 10:58 am
Hello,
My Skylift roof has a vent towards the back of it and was wondering if anyone has ever tried fitting a fan into that cavity? Its about 89 mm in diameter.
There is a 12 volt supply nearby so wiring it in will not be an issue.
I did have a quick google but have not yet managed to find a bi-directional fan of the right size to fit the cavity.
(I was thinking maybe a PC chassis fan could work here, but they are uni directional)
Thoughts?
TIA
Cuch
Bongolia
Re: Roof Vent Fan Ventilation
Post by Bongolia » Wed Oct 05, 2016 11:23 am
I think PC fans are simple DC just flipping the wires should do it shouldn't it?
cuchillo
Post by cuchillo » Wed Oct 05, 2016 11:26 am
Bongolia wrote:I think PC fans are simple DC just flipping the wires should do it shouldn't it?
I did consider that, but a couple of things came to light while checking Google. The blades are designed to be uni directional and they tend to have reverse polarity protection to stop you from mis-wiring it.
Don't have one to hand to test it :D
Post by g8dhe » Wed Oct 05, 2016 11:44 am
PC fans are NOT simple DC - they are speed controlled and unidirectional!
Bongolia
Post by Bongolia » Wed Oct 05, 2016 12:54 pm
Ahh!
Jimbobvfr400
Post by Jimbobvfr400 » Sun Oct 16, 2016 7:44 pm
Could you mount a PC fan on some sort of quick release mount, to reverse just flip it over.
Jamie, Caroline and the kids.
2002 V6 Aero AFT
redrocket
Post by redrocket » Tue Oct 25, 2016 11:35 am
There are many different types of PC fans out there, some 2 pin, simple positive negative, others 3 and 4 pin for speed control etc.
All i have ever tested will all work when you power positive and negative regardless of the other wires, just feel the air coming off to make sure the air is being blown the right way. This is not a bad idea, i find in summer i can go all night fine its when it hits around 7 - 8am im normally cooking inside.
cuchillo
Post by cuchillo » Sat Oct 29, 2016 5:23 am
So, here's a thing ....
http://www.magnummotorhomes.co.uk/en/Ro ... -Vent.html
Seems like one already exists!
Anyone seen or used it?
TIA
Bongolia
Post by Bongolia » Sat Oct 29, 2016 3:44 pm
Never used one but seen them on caravans and motor homes.
Where would it fit on an ATF though?
cuchillo
Post by cuchillo » Sat Oct 29, 2016 3:46 pm
Hello,
Bongolia wrote:Never used one but seen them on caravans and motor homes.
Not an ATF. It's a skylift roof from JAL that comes with a mushroom vent at the back of it. I think it's the same size as this vent so could be a straight swap out, plus a bit of wiring.
Least, that's the theory! :lol:
