Rear air con unit removal
Bongolia
Post by Bongolia » Wed Sep 21, 2016 2:40 pm
Hi peeps bit of help needed here please.
I will be removing the rear aircon unit and replacing it with a Propex heater.
My question relates to the flexible hoses.
There are two, presumably a flow and return, hoses running from the unit to the gearbox. What is the function of these hoses and could they simply be looped out.
Ta.
Re: Rear air con unit removal
Post by g8dhe » Wed Sep 21, 2016 2:45 pm
One pair is the coolant from the engine which provides the heating, the other pair for the Air Con for cooling.
Yeti
Post by Yeti » Wed Sep 21, 2016 2:49 pm
Hi Bongolia, I don't suppose you have/are removing the rear heating/air con control panel too? Ours is missing so I maybe interested if you are?
"It is his love, it is his passion"
"It is his fault he didn't lock the garage!"
Bongolia
Post by Bongolia » Wed Sep 21, 2016 3:15 pm
Yeti wrote:Hi Bongolia, I don't suppose you have/are removing the rear heating/air con control panel too? Ours is missing so I maybe interested if you are?
If you mean the interior panel then we will be re using that.
g8dhe wrote:One pair is the coolant from the engine which provides the heating, the other pair for the Air Con for cooling.
M y error , they are in fact the transmission cooler pipes ! :oops:
Note to self: lay on the floor and look up #-o #-o #-o
Yeti
Post by Yeti » Wed Sep 21, 2016 3:29 pm
Ah well, worth a try :D
