My 95 diesel's rad is looking a bit elderly, weeping slightly along top edge, and my regular garage has
recommended an ally radiator. Is this worth pursuing, and where would I get one?
Anyone done this?
Thanks all,
Derek
Aluminium radiator?
- Dr Fingers
Re: Aluminium radiator?
they are out there, over the years ive seen several and always fancied on myself, i wonder if they a custom made by one supplier as i cannot think of any other motor that has the oil cooling in the bottom. maybe the ranger is similar and you could then mount an oil cooler separate.
there is nothing wrong with the original mazda or the cheaper after market ones though, quality seems good.
try this
https://www.google.co.uk/webhp?sourceid ... urers%20uk
try these.
http://www.autoinsider.co.uk/local/car- ... i_1464.php.
http://www.autoinsider.co.uk/local/car- ... i_1256.php
try this
try these.
We have been dealing with Aaron rads for years now they are local to us. Not found anything they cannot refurb/handle, even made from scratch an intercooler for an MG special.
Great company bit pricey but you pays yer money etc..
If you mean an aluminium "Cored " radiator these are readily available from ebay ,eurocarparts, etc etc.Dr Fingers wrote:My 95 diesel's rad is looking a bit elderly, weeping slightly along top edge, and my regular garage has
Anyone done this?
Thanks all,
Derek
Or do you mean an all aluminium unit.
It seems that aluminium radiators are the norm nowadays, copper is but a happy memory.
i fitted a pattern radiator just over a year ago from Fastrads in South Wales. Came within a day or two and was much easier to fit than I feared and I ended up wishing that I hadn't wasted so much time and effort over the previous few years patching up the leak around the top seal of the original radiator (which turns out to be aluminium anyway). Have had no trouble with it and it should see me through all the next age related Bongo woes.
Fitting presented no problems, other than that I nearly threw away the two big steadying grommets it sits in with the old rad. All the pipes came off and went back on easily.
Obviously, follow the bleeding procedure meticulously when refilling the coolant. Every Bongo owner must know that by now!
Frank
Frank
They flew, I took up naturism
